13:1 c/r on pump gas?
not dictate when the intake valve closes.
Intake centerline is at times used to dial in camshafts, but even that cannot
tell you IVC because the duration my differ.
YOu need to use Intake Valve Closing (IVC) to determine the dynamic compression ratio.
For eg I run 25 deg through pk torque with a 232 234 112 I have a 46 deg IVC, with a 227 239 115 cam. in the same engine it has a 45.5 IVC it makes best tq at 28 degrees but it still wont knock with 32 degrees, the 112 cam will knock at 26.5 degrees, Even though the cranking compression is less with the 112 cam it takes less timing. Why? Because the extra overlap is scavenging and filling the cylinder better. cranking compression is a guide, Even going the same cam even slightly wider in lobe sep and a mere 2 deg later ICL can change things drastically, Overlap drops off running cylinder pressures drop off, all of a sudden the motor is taking more timing. This is normally what we do if the compression is to high, Even the same motor same parts can be different.
your last post.
Scavenging / overlap that you are tweaking improves cylinder filling which
increases the amount of charge presented to the chamber. This creates
a higher cylinder pressure.
When you degree a cam by shifting ICL by 2 degrees you are effectively
phasing all valve timing events...which directly alters dynamic compression
because the IVC event has moved.
Think of it this way:
A camshaft with the exact same lobe installed at the same intake center
will have the same DCR even if the lobe separation changes (110 to 112 LSA for example).
Overlap changes, but DCR does not in the above scenario.
DCR is just a mechanical ratio of when the intake valve closes based on the
amount of static compression available.
If you have a small motor with a ton of cam in it it may want the upper end, but i dont think Id build buzzer for pump gas drive around duties.
When we built a LS motor originally at 13:1 dropped down to 11.5:1 saw virtually no loss in power, it was filling the cylinder. Even on high octane fuel the difference was little to none
Get the combo right and you dont have to rely on rolling the dice on compression, and youll have a tuning window with some margin. Just did a 408 LT1, hyd roller, forward facing intake made 466 thru a 5200 stall on our Mustang dyno. Decent CYlinder head and cam timing are close, not abunch of compression just 11.3:1
And your not going to want a dome in a chamber running on the edge of pump gas capabilities. Get the piston right to start
I tried for many years to get away with 10.9/1 c/r, and after trying many after-market inventions I simply bit the bullet and mixed LL-100 AV fuel with pump 92 octane, and only then was I okay and actually got to enjoy my high(er) compression. If your local municipal airstrip won't sell you the (100) AV gas, then you'll have to pay the price via your local speed/off-road shop.
If you try to run high compression with pump gas your expensive motor will suffer (and not last long). Years ago someone built a 12.5/1 350 sb, it could pull the front of his Vega off the ground with good traction - but his motor was always noisy only lasted 8-10,000 miles (that was with 92-93 octane & so-called 'octane boost' - which only boosts your octane about .5 -.7 {½ to 3/4 octane, or "five to seven octane points"}
If you don't have access to better fuel don't use more than 9.3-9.5/1 c/r (!)
Wow disregard everything this guy just said, most of them are 10.9:1 from the factory now bud
SBC's are different.
I'm thinking that maybe 12.5:1 on pump gas is doable, but I wonder what sort of compromises there would be with respect to timing advance...
If I build a new NA motor next year to run on 93, no meth etc., I'd probably go about 11.75:1.
A very well thought out engine that moves air isnt going to car much about a hair more compression. Waste of time.
I have dropped a point made the combo happier and picked up bunch of power. Compression is what you use when you cant fill the cyl well, squeeze the **** out of it!
Build 14.1 CR LS on E85 DD
DM
LSA has nothing to do with intake centerline. LSA however has everything to do with exhaust centerline.
I don't think there is any specific static compression ratio that is "safe" I think as others are saying too, it is about the full combo. Everything must work together to achieve a harmonous motor that will make great power.
No, i can build a motor that runs 13.5:1 on 93 octane pump gas no problem. And itll probably be a f'ing pig. but you could do it.
Fill the damn cylinder, dont get carried away with compression, and have at it. There are certain circumstances you turn to compression when you dont have other things in place, but in a perfect world, no
on RPM and what sort of pressures are occuring in the exhaust system; the
chamber; and intake system at that specific point in time the valve is open.
Sometimes reflections and odd pulse phasing in the motor will prevent gasses
from clearing out.
Also to clear things up:
LSA, or LCA is the value given between the exhaust centerline and intake centerline.
Volumetric efficiency is a cousin to cylinder pressure (IE: BMEP, IMEP, etc.)
DCR is just a mechanical ratio of when the intake valve closes in relation to
the total amount of Static compression.
IMEP = ((792000 x HP) / (Meff x CUIN x RPM)
Meff = mechanical efficiency = (-0.000009 x RPM) + 0.9188 (typical values)
Peak Pressure = (((IMEP / FIT) x (((CR - 1) x (y -1)) / ((CR^y) - CR))) + INT) x CR^y x 0.75
FIT = Correction Factor found in complex engine sim calculators.
CR = Compression ratio
y = Ratio of specific heats.
INT = Intake manifold pressure PSI (absolute)
BMEP = 150.8 x TORQUE (lb-ft) / DISPLACEMENT (ci)
