Advanced Engineering Tech For the more hardcore LS1TECH residents
JE Pistons Asymmetrical Skirts
Old 12-14-2010, 07:34 PM
KCS
Moderator
KCS's Avatar
Default JE Pistons Asymmetrical Skirts
Anyone see this at PRI?
JE is going to switch all of their pistons to this design.
Old 12-14-2010, 08:50 PM
BigRich954RR's Avatar
anyone try them yet ?
Old 12-14-2010, 11:47 PM
Ethan[ws6]'s Avatar
Doesn't sound like anything special to me. We'll see though.
Old 12-15-2010, 05:01 PM
LS1TECH Sponsor
Ryne @ CMS's Avatar
i saw it at pri as well, i would be interested in the logic/engineering behind it
Old 12-15-2010, 05:11 PM
$750 L98's Avatar
From a purely amateur and non-technical standpoint, the design scares me a bit. It seems like there is more chance for rock or unequal placement of side to side forces during the stroke? It also looks like the ring lands would be weaker and more sensitive to detonation or microscopic flaws in materials.
Real, raw, testing is the only way to see how it pans out. If it does, I'd be interested in a set some day, they look crazy light!
Old 12-15-2010, 11:07 PM
86zcamaro's Avatar
They said something about it having less resistance because of design and that it makes slightly higher numbers. There was an article somewhere off this sight about it.
I too would like to see a difference worth noting and maybe to see if this design is more reliable than standard designs somehow.
Old 12-16-2010, 08:41 AM
KCS
Moderator
KCS's Avatar
It seems like they did these for some import applications (Supre/Eclipse/etc) and just stumbled on a design they feel is better.
Seems like a good design to me. A nice broad skirt on the thrust side to support the piston, and a reduced skirt on the trailing side where it's not really necessary to drop weight and reduce friction. I'm sure the pin offset could keep rock under control, if there is any more than normal anyways.
Interesting nonetheless.
Old 12-16-2010, 07:54 PM
Always2Slow's Avatar
The design is very good for a N/A motor as the thrust side of the piston sees a more abusive force on the ring. This will help the connecting rods last longer when spinning the motor up pretty high.
Old 12-16-2010, 08:18 PM
Shawn @ VA Speed's Avatar
JE is going to making a set of these for an ls engine out of billet. We are going to be testing these for JE in a few months to see how they work out. I believe they have some attributes that will work well.
Old 12-17-2010, 09:53 AM
KCS
Moderator
KCS's Avatar
Care to share any details?
Old 12-17-2010, 05:01 PM
UNDER PRESSURE MOD
The Alchemist's Avatar
So how much lighter are these? Are we talking less than or more than 5oz?
Old 12-18-2010, 07:43 PM
more thrust surface will be great on these long stroke short rod engine,more piston stabilty leads to less piston rock,better ring seal and more power. the smaller skirt on the other side leads to a lighter piston and less cylinder wall drag.
Old 12-18-2010, 08:06 PM
UNDER PRESSURE MOD
Sounds promising.
Old 12-20-2010, 12:22 AM
OWN3D BY MY PROF!
Beaflag VonRathburg's Avatar
It sounds like an interesting design. I like to see new technology come out for something even as old as the piston.
Old 11-20-2014, 11:47 AM
futureuser's Avatar
Any updates?
Old 11-22-2014, 09:31 PM
Sslivin's Avatar
I called and tried to order a set for my 5.3L but they don't make any of these for a bore smaller tha 4.xxx.
Old 11-25-2014, 01:13 AM
futureuser's Avatar
testing results?
Old 11-26-2014, 11:06 PM
GSAWYERS's Avatar
I've seen 2 sets of these go in motors at work. Not in an LS. They both made big power, didn't have any failures but not sure if they were better than typical JE or CP or ... It would be a little advantage to get a lighter piston that would hold up. If you were looking for every bit of power or were trying to get an advantage in a restrictive racing class they'd make sense. On a street car it's cheaper to use a quality piston and go up a jet size or add a psi or 2 and get the hp increase.
Old 11-27-2014, 06:46 AM
LSPerformance's Avatar
Marketing gimmick LOL
Old 11-27-2014, 08:31 AM
Old School Heavy
speedtigger's Avatar
Kind of surprising somebody hasn't done this already.
Quick Reply: JE Pistons Asymmetrical Skirts
