Hydrogen powered car guide..pros n cons
Looks nice, but whats the real effect of burning hydrogen thru a gazoline engine instead of gaz?
I will test it for real...
http://www.hybridwaterpower.com/?hop=830903
Some kits on Ebay. Looks neat with the map sensor; http://cgi.ebay.com/Juicers-Hydrogen...#ht_5849wt_901 BUT I'm saying to myself this should be tuned on a dyno to monitor A/F ratio to be sure its safe for the engine. Plus I'm wondering if we should adjust timing and replace spark plugs too..
dyno sheet 5th image:
http://cgi.ebay.com/1-Hydrogen-Gener...t_12053wt_1135
Another thing is I dont think it would work with a Carburator, unless running a stand alone with a 'switch' mode between the Hydrogen and gaz.
I wish some hardcore LS1tech guys tested this already!!
If you burn hydrogen slow enough you get negative cylinder
pressure. It likes high speed and high compression.
Modifying the combustion dynamics of the gasoline burn is a
whole different matter. Even stuff like swirl and spark intensity
have effect. But you're not running on swirl. And your HHO
setups are not "running on hydrogen".
1.new energy ideas website. http://peswiki.com/index.php/News.
2.breakdown. http://pesn.com/2011/05/25/9501834_W...ency_Evidence/.
3.proof. http://www.eagle-research.com/erpdf/...oofs110316.pdf.
4.fred wells research. http://pesn.com/2011/05/08/9501829_F...Concept_Truck/.
Also, the laws of thermodynamics stop this from holding true.. Your link that claims it doesn't is complete bullshit. Actually, half the **** on those links is either irrelevant or retarded.. Claiming that "combustion is a chemical process not a thermo on so the laws of thermodynamics don't apply" is completely wrong and not even something that should be disputed with this concept. Maybe you should learn something about physics before trying to defend a concept like this. A grasp on some knowledge of Stoichiometry might do you some good too. It really shouldn't be this hard for normal people to understand.. you CAN NOT get more energy out of an equation than you initially invest.. end of story.
You are not "capturing wasted energy". You're taking prime shaft power
(after inefficiency) and using it to run a very energy inefficient process
(electrolysis) in the hope of getting better than breakeven. But you can't.
And you won't.
Your alternator doesn't waste much shaft power, and when you draw
current your shaft load is what supplies it. Ain't nothing free. And conversely
your parasitic drag can't turn into power just because you hook a cell to it.
Call it the Barnumtron.
http://en.wikipedia.org/wiki/Cold_fusion#Explanations
if you read any of this, you will realize why you are retarded for mentioning cold fusion.. Just because you read one website that claims something is possible, or true in any aspect, that doesn't magically make the ones that say it isn't possible disappear..
And you won't.
What if you had those recharging brakes like the prius or whatever and instead of having a huge expensive and heavy batter and electric motor, it just made hydrogen to use as a fuel?
Edit: also not to mention making oxygen "H2O" Wonder if this would help an N/A motor more so in high altitude areas?
