Camless engines...
http://www.dart-mouth.com/engines.html
The Wankel was supposed to be the new greatest thing, but it has never been able to achieve acceptable fuel economy and emissions is a struggle as well.
Some more info on their site:
http://www.coatesengine.com/csrv-system.html
The goal of the project was to run the engine on both the Otto cycle AND the Miller cycle so you could have power when needed or fuel efficiency, repsectivly.
I was able to switch between the two cycles succesfully, proving the concept(as I'm sure many others have been able to do), but the solenoids would only react fast enough to get me up to 1700 rpm. Additionally, the power consumption to pressurize the cylinders was quite high(reducing the effectivness of the miller cycle). And being a senior design project the durability wasn't exactly 100k mile type stuff.
I don't think hydraulic will be the way this stuff gets into production due to issues with the fluid inertia at higher rpm's.Navistar had one of their heavy hitters make the Pike Peaks run in a pure camless engine that Sturman Engine systems developed for them. Not sure why they never took it to production. And while not camless, the Skyactiv achieves both otto and miller cycles throughout the entire rpm band. This technology would be killer for a vette that could maintain a smooth idle but then open up duration/lift at higher rpms, can control overlap so there isn't any reversion back up the intake manifold. Not sure anyone OEMs need to drop the cash to make it happen thoughsince everyone already has a plan for the CO2 emmisions.
If I remember correctly from the story he told. As an engineering student for GM and touring through their plant somewhere around 1983, GM had a 1ltr 4cyl that used valves controlled by electromagnets with springs on the bottom side of the head that held the valves open until the coil pulled them closed. This little treat was supposedly a full composite engine cooled by R134 refrigerant.(In 83 they were still using R12 and haven't introduced 134 in AC systems yet). The story tells,if I remember correctly, that valve events were controlled by a crank trigger type system and fueling was a direct injection style with pressure in the range of 1500psi boasting 300hp. There was no starter and starting was controlled with sensing which cylinder to inject and fire. i'm sure there was more to the story but it's been a few years since he was here to fill in for another NAPA trainer for a engine performance class.
Wish I could remember his name and see the story posted by him here.
