Camless engines...
Potential for it is great MPG putting around, and max power at WOT without having to change cams to find a happy middle ground or extreme to either side.. or for those that like big cams, re-tune the PC for larger duration/life all of the time! Less rotating mass all around on top of that. I know there is some limiting factor or someone like mercedes would have already mastered this.. but what is that factor?
I would think your main limiting factor would be the crank/ rods with holding a super high piston speed....as fee as cooling for the solenoid cooling is think keeping them in a flowing oil bath would do the trick, but not sure.
I've always liked the ideas of this, or even this combined with a rotory valve
also, think of all the problems the DOD/AFM motors are having. I assume it would operate on the same pricipal of computer activated solenoids, and without some serious money sunk into R&D, I dont see this being much of something we will see in the near future.
Plus the DI craze will hold consumers over for the time being.
Just think for a second what the torque curve would look like
This style valvetrain in a high compression DI motor, you'd be looking at retarded amounts of power with great street manners, and even better gas mileage than we get out of 6 speed LS cars.
As for di motors.. they still have some kinks to be worked out. Sludge buildup being a huge one...
Electromagnetic actuators for valves.. there's a wild idea! I knew about the pneumatic but that's the first ive heard of the other. I'm going to have to look into that. I would imagine its similar to the mag Lev trains and rollercoaster tech that's out there. Some serious power and potential in that kind of electromagnetic design. Activation and de-activation is slightly delayed though isn't it maybe that's why we don't have that available haha.
2. Electromechanical Ball Valves
An alternative to the conventional poppet valve for use in camless valve trains is a ball valve. This type of electromechanical valve system consists of a ball through which a passage passes. If the ball is rotated such that the passage lines up with other openings in the valve assembly, gas can pass through it. (Exactly like the ball valves many of us use to control our boost.) Opening and closing the valve is accomplished by electromagnets positioned around its exterior.
Referring to Figure 10, the valve housing (7) is shown in two pieces. Ball valve (8) has two rigidly attached pivots (12). The disc (10) is permanently attached and indexed to the ball valve and contains permanent magnets around its perimeter. The electromagnets (11) are situated on both sides of the ball valve (8) and they are fixed to the valve housing.
The electromagnets are controlled through the ECU. A crank trigger sensor on the crankshaft provides information about the position of the pistons relative to top dead centre. Thus, at top dead centre of the power stroke, the ECM could be used to fix the polarity of both electromagnets so that they are of opposite polarity to the magnets in the ball valve, rotating the ball valve to the closed position.
The substitution of a simple, efficient ball valve and valve housing arrangement in a a four stroke reciprocation piston engine eliminates all the independent moving parts in the valve train. This may even be an improvement over the poppet valve camless system - the ball valve needs only to rotate on its axis to achieve the desired flow conditions, rather than be accelerated up and down in a linear fashion. A partially open ball valve state may also be able to be used to create more turbulence.
Electromechanical valve train implementation would not be possible with a normal 12V electrical system. As has been covered previously in AutoSpeed ("Goodbye 12 volts... hello 42 volts!"), the automotive industry has chosen a 42V electrical system as the next automotive standard. Consequently, the energy demand of EMVT can be optimally matched by a crankshaft-mounted starter-generator (KSG - in Siemens speak) operating at 42V; it is integrated in the flywheel and designed for the starting process as well as generator operation.
Their digitally activated valve engine: http://www.sturmanindustries.com/mai...eActuation.htm
Williams F1/Renault have been working on the camless design for years. Still, a major hill to climb is interference from the F1 engine and the solenoids. Here's a wonderful article on pneumatic and electronic solenoid designs, a simple breakdown. http://scarbsf1.com/valves.html
I'm hoping to see koenigsegg's creation come to life here in the future. It would be a major step in development. I would love to get my hands on one and try to understand the programming of it.
