Advanced Engineering Tech For the more hardcore LS1TECH residents
viper upgrade
Old Dec 8, 2012 | 06:37 PM
M1SERY's Avatar
Arrow viper upgrade
looking for a company thats has the viper input shaft machined down to fit my t56 trans.
thanks for any help
has anyone had problems with the round out on input shaft in there t56 transmission?? or bent /twisted??
Old Dec 9, 2012 | 11:28 AM
The Alchemist's Avatar
UNDER PRESSURE MOD
Try posting this in the transmission section.
Old Dec 9, 2012 | 09:55 PM
solidws6's Avatar
got mine through d&d years ago.
Old Dec 15, 2012 | 01:45 PM
Sierra Speed Shop's Avatar
thanks for any help
Is the part already out of the transmission? We have full access to a machine shop, and can do custom work. If you know the dimensions, we can help.
-Kyle
Old Dec 26, 2012 | 11:00 AM
ckpitt55's Avatar
tick performance has all the parts for that stuff.
http://www.tickperformance.com/ticks...transmissions/
from their website:
Upgrade to Viper Mainshaft:
Includes everything that you need to convert your stock mainshaft over the much stronger Viper unit, including our Custom-length Viper 30-spline Mainshaft, Modified Speedometer Wheel, New Tremec Transmission Extension Housing (Custom-Machined for Viper Mainshaft) with no core charge, Viper-sized Output Shaft Bushing, Viper-sized Output Shaft Seal, and Yoke. This upgrade will increase the torque rating of your transmission to 550ft/lbs (rear wheel.)
Old Jan 4, 2013 | 09:42 PM
Blackpanther99's Avatar
Tick has some of the bestest parts for T-56s
Old Jan 5, 2013 | 12:48 AM
t_raven's Avatar
I know the Viper input shaft is longer than the LS1 input shaft but how are they different other than that? They are the same spline count right? I need a new input shaft and if a machined down Viper input is some how better than a replacement LS1 input shaft, I might want to go that route myself.
Or did you mean to say main shaft?
Old Jan 21, 2013 | 07:00 PM
roadracer380's Avatar
This may sound hack but I cut mine down with a cut off wheel on my old Camaro and drove it for 20,000 miles without a problem
Old Mar 4, 2013 | 06:15 PM
z28josh's Avatar
Jason at texas drive train performance can do a 31 spline shaft that he has machined to fit and his prices aren't bad either. Mine has it been running great for the past few years.
