Advanced Engineering Tech For the more hardcore LS1TECH residents
Ceramic coating
Old Jan 11, 2013 | 07:02 PM
trevmust's Avatar
Default Ceramic coating
Has anyone here ceramic coated their cylinder heads, intake manifolds and pistons? If so any opinions? I have heard people complain about piston rings suffering because of that, but can you not ceramic coat piston rings too?
Old Jan 11, 2013 | 07:48 PM
joecar's Avatar
No, because they will bind on the piston.
Typically you get headers ceramic coated since this better retain heat in pipes which keeps the gas velocity up.
Old Jan 11, 2013 | 08:26 PM
trevmust's Avatar
Dart does a bunch of different coatings, would an oil shedding coating be beneficial? what does that mean, it has less drag? or...
Old Jan 11, 2013 | 08:33 PM
joecar's Avatar
Oil shedding coating on inside of block is to promote better oil drain back into pan (to keep oil pickup covered).
Old Jan 11, 2013 | 08:54 PM
trevmust's Avatar
oh cool. yeah dart will do the crank, underside of pistons, connecting rods, interior of oil pans for sure and the underside of the intake I think.
Old Jan 11, 2013 | 11:08 PM
CCPcoatingscom's Avatar
Ceramic coating pistons is most common followed by intake manifolds, combustion chambers and valves. So much so that you'll likely be seeing these coating on OEM vehicles in the very near future. Reason being, OE's have determined that your typical engine with aluminum block, heads and pistons loses upwards of 30% + thermal efficiency.
Why would piston rings "suffer" from coating heads, intakes and pistons??
Old Jan 13, 2013 | 08:33 AM
Blackpanther99's Avatar
I understand now, even though I didnt ask the question lol. Very good info. Soo can powercoating a block affect the performace of it?
Old Jan 13, 2013 | 11:10 AM
Not really. It's just a better way to keep it looking nice. GM powder coats their LSX blocks and many of their crate engine assemblies and then has them machined. They had us powder some of those in clear as well as heads, intakes and cranks for their mobile displays a while back. We've done some similar work for AM General as well.
Old Jan 13, 2013 | 04:07 PM
trevmust's Avatar
People say the increased heat blows the rings out sooner
Old Jan 13, 2013 | 04:30 PM
That doesn't seem very logical now does it? Why would it be hotter when its absorbing LESS heat? In reality the piston will be cooler after having its dome coated as it's rejecting more heat.
When you have excessive temps in a cylinder with a standard un-coated piston you will get burned/melted domes or stuck rings as a result of piston distortion or physical melting/welding from the heat.
Coated pistons will give you a much bigger safety margin to avoid the melted pistons. If things get really crazy though, since the heat can't really make its way through the piston any longer, the new path of least resistance is going down the cylinder to the ring land or skirt area.
Unfortunately If you make a big enough boo-boo even coating won't help you.
Old Jan 14, 2013 | 02:35 AM
trevmust's Avatar
yeah i was confused too.
Old Jan 14, 2013 | 10:23 AM
They were likely trying to say the same thing but it got lost in translation.....
Old Jan 14, 2013 | 03:55 PM
trevmust's Avatar
I think they were trying to say that the heat reflection makes the Cylinder temps higher.
Old Jan 29, 2013 | 02:48 PM
Ahh I see, thanks for the response. Ive always wondered if it was bad or not.
Old Jan 29, 2013 | 02:53 PM
Soo coated pistons can basically be more safer at higher temperatures correct?
Old Jan 29, 2013 | 03:22 PM
01 ss vert's Avatar
Are you sure about either point?
I fairly certain coatings on the headers are not for velocity flow (temp in not a variable in flow – shape and Reynolds number are) but rather to keep temperature down in that area (hence, displacing heat from the engine bay and extracting it out the exhaust).
I’m 99% sure ceramic coating does not help ‘air flow’ – if it did, the entire inside would be coated. It’s simply an insulator to prevent heat from conducting under the hood and heat soaking everything else.
Old Jan 29, 2013 | 05:51 PM
trevmust's Avatar
the heat protection is on the outside and the other kind of coating for the inside is supposed to make it flow faster
Old Jan 30, 2013 | 07:45 AM
01 ss vert's Avatar
I've never heard this, and don't buy it without proof. Keep in mind, flow and velocity are two different things. And to be fair, yes, I have had ceramic coated headers before- but that was to prevent rust and under hood temps - not for "faster flow."
Old Jan 31, 2013 | 11:19 AM
I personally dont buy it either with no proof, but hey i could be wrong, with all this technology now days it could be possible.
Old Feb 5, 2013 | 12:36 AM
SleeperZzZ28's Avatar
maybe the porous nature of the ceramics can promote flow like a golf ball. Smoother surfaces are "stickier" as air passes by more surface area. So maybe ceramic coating the interior of headers and other internal combustion areas can actually see a slight improvement?
