Advanced Engineering Tech For the more hardcore LS1TECH residents
SolidWorks Project Suggestions
Old Nov 5, 2013 | 05:25 PM
ZouMechE's Avatar
Default SolidWorks Project Suggestions
I have to complete a final project for my solid modeling class. We have to design a system. That doesn't necessarily mean it has to be a system consisting of moving, mechanical parts. It could be something for which we could model the flow of air, fuel, etc. I've come here to see if anyone has any suggestions of any ideas of parts or systems, relating to LS cars, or any vehicle for that matter, that they would like to see rendered.
Thanks guys
Old Nov 13, 2013 | 04:33 AM
texas94z's Avatar
I think AFM or VVT would be very challenging to model and simulate.
Old Nov 13, 2013 | 10:42 AM
Ryans99ls1's Avatar
The front clip of an Fbody and more specifically the effect of the air dam on the cooling system. A lot of FI guys remove that and wonder why they are overheating
Old Dec 6, 2013 | 06:08 PM
BAT TA's Avatar
You could try modeling the different mounting configurations of air to air intercoolers on a trans am vs. a camaro to determine which are the most efficient. I wish we got to pick our own projects, I'm about to spend my Saturday doing position, velocity and acceleration analysis on a freaking elliptical machine.
Old Dec 6, 2013 | 10:53 PM
Wnts2Go10O's Avatar
unless SolidWorks can do CFD.. i doubt that
Old Jan 13, 2014 | 08:11 PM
iliveonnitro's Avatar
There's a good chance his school has a license for a CFD package, especially if part of his assignment is to model fluid flow.
If you're an undergrad, keep it 1D SS flow..or maybe 2D. 3D would be much too hard and time consuming. An intercooler or HC injection on a diesel aftertreatment system would be good.
Old Jan 17, 2014 | 11:12 AM
cajundragger's Avatar
I'd personally do a suspension system and avoid anything fluids or heat trans.
anything native to solids works isn't very accurate and hard to use. I know at LSU we didn't have the full package for CFD and heat trans but we did have the full FEA package.
if you need any help let me know. I basically do 3D modeling(solidworks) for a living and am a MechE.
Old Feb 10, 2014 | 01:34 PM
Forcefed86's Avatar
My vote is for factoring actual exhaust gas velocity and ACFM readings in different sized piping (hotside piping) of a a turbocharged LS engine.
Old Feb 25, 2014 | 11:03 AM
smitty2919's Avatar
I did a Portable Co-Generation system for my senior project when I was in school. Idea was to use a lawn mower/car alternator to heat water and produce electricity to power a house hold fan.
Used SW to model up a small radiator with fins then modeled a box around it to have exhaust gas from pass through it to heat water running through the radiator.
I did the CFD on it to have a visual of the exhaust gas flow. Did all the heat transfer calculations separate though. It served more as a visual representation more than getting actual values.
