Advanced Engineering Tech For the more hardcore LS1TECH residents
piston
Old May 19, 2017 | 01:02 AM
atti.54321's Avatar
Default piston
what is the formula for piston instantaneous velocity ?
Old May 19, 2017 | 02:07 AM
pantera_efi's Avatar
Default Max ????
Hi, not at this time.
I have a start : V=M x the weight of the Universe in grams (10*55) divided by distance.
FAR faster than the speed of light.
I use Piston Speed AND Piston "Gs" AND Piston Acceleration to solve some cases ?
What is your reason ?
Lance
Old May 19, 2017 | 02:12 PM
joecar's Avatar
This is not what you're looking for:
Piston Mean Speed [ft/min] = RPM x stroke[inch] / 6
This is what you're looking for:
v(A) = -R.sin(A) - R².sin(A).cos(A)/sqrt(L² - R².sin²(A))
where:
v(A) = piston instantaneous velocity in [inch/rad] at A
A = crank angle in [radians] (0 = straight up = TDC)
R = crank radius in [inches] (center-to-center) = 1/2 x stroke
L = connecting rod length in [inches] (center-to-center)
see red curve in graph attached.
To convert v(A) in [inch/rad] to [inch/s] at some RPM you have to do this:
convert RPM to angular velocity w like this: w[rad/s] = 2.pi.RPM/60
then in v(A) replace A by wt and multiply v(A) by w to get v(wt) like this:
v(wt) = -w.R.sin(wt) - w.R².sin(wt).cos(wt)/sqrt(L² - R².sin²(wt))
this gives the instantaneous velocity in [inch/s] at time t[s] at any engine speed w[rad/s] where t=0 is TDC.
Old Jun 2, 2017 | 12:47 AM
Dian's Avatar
nice. what is the reason velocity is asymetrical?
Old Jun 2, 2017 | 02:58 AM
joecar's Avatar
Because the piston takes longer to go thru the bottom compared to the top, look at the position curve (the blue one).
Old Jun 4, 2017 | 10:04 AM
Default Piston Pin Offset
Hi Joecar, good report with respect to an "on center" Piston Pin.
Would you make the same style of report with an "off-set" pin (OEM) as used in a LS-x engine ?
Would you make the same style of report with a reversed pin "offset " as I do fit at times with a LS-x engine ?
Lance
Old Jun 4, 2017 | 07:46 PM
joecar's Avatar
Hi Lance,
Thanks.
I have a similar analysis for non-zero offset piston pin, I will post it as soon as I get to a PC.
( BTW: I noticed you're in Santa Ana, I'll come and visit you sometime )
Old Jun 4, 2017 | 08:06 PM
joecar's Avatar
Hi Lance,
I have a couple of quick questions before I generate the graphs for non-zero offset piston pin...
1. what is the stock offset used by GM...?
2. is GM's offset in the same direction as crank rotation (i.e. toward piston low-thrust side)...?
3. is the reverse offset in the opposite direction of crank rotation (i.e. toward piston high-thrust side)...?
4. I'll assume stock stroke 3.622" and stock rod length 6.098"... are there any other stroke/rod combinations you want see...?
Old Jun 4, 2017 | 09:32 PM
joecar's Avatar
Lance,
Here is an example of exaggerated piston pin offset +/-0.5" compared to zero offset, see attached image
( in practice it would be less than 0.1" );
equation is:
v(A) = -R.sin(A) - (R.sin(A)-k).(R.cos(A))/sqrt(L²-(R.sin(A)-k)²)
where k = offset as shown in the second image (positive offset being in same direction as crank rotation);
( so for OEM offset, k would be negative )
when k is zero this equation reduces to the one in post #3 above.
Old Jun 5, 2017 | 09:45 AM
Hi Joe, we are now a team ?
YES, please visit with an appointment made by phone first.
I will show you my BAS progress.
Those here, ALL, who "speak" piston tech NEVER have stated the benefits of Pin Offset. (SAD)
YOUR HELP has shown this effect in an easy to read picture.
I use EAP to generate the same, a similar picture.
The MAX C.R. for Engine Knock Resistance IS effected by Pin Offset.
EXAMPLE : LS-427
1. This is a 4.1" stroke by 4.065" bore with LS-2 heads.
2. The C.R. is 12:1, a value that could scare a person with 93 octane.
3. The use of an "offset pin" piston WILL ADD Knock Resistance when in the OEM direction.
4. The use of an "offset pin" piston will allow the LS-2 port head to flow MORE air into the cylinder, with OEM direction.
EXAMPLE : LS-3 OEM with RaceTec Offset Piston.
1. The Hendrick head, the LS-3 head, flows the air required for a Cup Engine and WHEN "matched" to a non OEM piston offset will make better Torque.
2. The same is true with the Dynamic Compression, the piston will remain higher in the cylinder at a higher BMEP with an increase in Torque.
I believe YOUR WORK may answer a common asked question made by LS-1 Tech members.
I thank you and hope others will do the same.
Lance
Old Jun 5, 2017 | 10:47 PM
joecar's Avatar
Hey Lance,
Yes, we're a team this is a very interesting topic.
I'll check my schedule first and I'll call you ahead of time.
So OEM piston pin offset is in which direction...?
( in the geometry picture I posted above, is that OEM offset...? )
Old Jun 5, 2017 | 11:52 PM
kingtal0n's Avatar
For fun, I did this a while back. First I made the calculation on paper, then I wrote a small piece of software so I could find other rod/stroke/rpm more easily.
Enclosed is the program (requires VB runtime), the source code, and the initial paper calculation.
It isn't as advanced as what Joe posted, it just uses basic math based on rpm and angles/lengths.
File Type: zip
File Type: zip
Old Jun 6, 2017 | 12:10 AM
joecar's Avatar
I'll take a look when I get to a PC.
Old Jun 9, 2017 | 02:03 PM
joecar's Avatar
Hi Kingtal0n,
Too much special case math obscures what is going on... you can generalize it, especially the derivatives wrt angle and wrt time... see this wiki I wrote a few years ago, it outlines the derivative math and it shows how to convert from angle to time using calculus identities (you could do the derivatives wrt time, but doing this is tedious, it comes out the same, and it is more fun to use the calculus identities).
See attached doc for non-zero offset (OEM offset would be negative)... if you insert those equations into a VB program with L, R, K as parameters, and run x from -360° (-2pi rad) to +360° (+2pi rad) you can get a nice plot of x, v, a.
I used a general purpose plotting tool called DPlot.
File Type: doc
Old Jun 9, 2017 | 08:35 PM
joecar's Avatar
Can someone confirm this:
i.e. in opposite direction of crank rotation (toward thrust side of cylinder wall).
Old Jul 14, 2017 | 12:01 PM
Default Pin Offset
Hi Joe, it WAS confirmed in the above graphs. (yours)
Allow me to state : When the offset is on the throw side in the DOWN direction of crankshaft rotation, the effective compression will be HIGHER/intake port flow requirement HIGHER.
When the offset is normal, the throw side will be on the UP direction of crankshaft rotation with pin to the block center (RH not LH rotation), the effective compression will be LOWER/intake port flow requirement LOWER. (OEM)
Thus a high static C.R. AND small intake port WILL work better with the GM OEM designed inboard offset.
This will work for BOTH engine rotations. (LH/RH)
NOW what I DO NOT UNDERSTAND is NO Mention of this effect, your Joe's/King's fine work, with respect the "Effective Compression" thread ?
Lance
Old Jul 15, 2017 | 07:49 AM
smokeshow's Avatar
Lance
Nobody mentions that because any airflow differences due to a change in pin offset are well within a standard margin of error for our measurement tools. Manufacturers don't utilize an offset for performance; it is for cold engine NVH improvement.
Old Jul 17, 2017 | 11:21 AM
Default Large Port + Pin Offset
HI Jake, my concern (1971) was to "fix" the Large Ports used in the BOSS 302 Ford emgine.
We used an offset piston pin location (opposite OEM) for that fix.
The piston "dwell" is better for a larger port (Boss 302) with results of Torque increase at ALL RPM AND an HP increase of 18-20 HP for a 500HP engine.
The OEM's DO consider Noise Vibration Harshness with MY report of their concern during my Camless Engine bench dyno tests.
As for manufactures concerns, they DO though there may be other requirements for their needs than peak power.
Lance, BTW MY dyno has an inlet air measurement turbine.
Old Jul 17, 2017 | 12:10 PM
smokeshow's Avatar
I see that you're responding to me, but I don't understand the relevance of really anything you're saying. It's all so far into left field i find myself wondering if you are responding here to a topic in another thread.
Old Jul 17, 2017 | 03:11 PM
Default Piston Pin Offset.
Hi Smoking, READ the above GRAPHS, there are three colors.
They state airflow requirement AND piston acceleration. (the Left, Center, Right offset).
The effects are easy to measure, DONE by my bench dyno's airflow turbine.
I do not know how to be more clear both with the Math (not mine) and Measurement.
THUS YOUR statement of the LACK of ability to measure Air Flow = Untrue
Lance
