Smaller rod journals in LS?
But if you're using state of the art heads and intake along with a llsr, vacuum pump, lightweight drivetrain etc. then I would think this would go on the list to look at.
https://ls1tech.com/forums/parts-cla...rankshaft.html
The engine requirements ARE high RPM (9000+) AND LOW BMEP, thus no Turbos/SC/NOS.
The costs do do so is OVER 10,000 USD, the Billet Crankshaft@6K, the Billet Rods@3K, the .750" M-350 DLC pins@1K.
AL Main CAPS with "spacers" ???
I would STATE WHEN an AL billet main cap is fitted, the bearing Clearance MUST BE less than .001".
THEN there is the cost of the heads/valve train, I would fit the Mercury Racing FOUR Valve head conversion.
Lance
