Importance of LOW Crancase Pressure
The same negative (or less positive) pressure that is "helping" pull the downward traveling pistons is also "hindering" the upward traveling pistons.
Would that not balance out?
Seeing steady pan vac is good. A fluttering/unsteady pan vac indicates you're rattling the rings. A pan vac that gets higher and higher each pass indicates you likely hurt something.
Related question: what's a good sensor to use to measure crankcase pressure? I'm about to get a dry-sumped engine, and I've got an unused breather port on one of my heads, so...
There is less aerodynamic resistance in a vacuum but the vacuum created by the dry sump wouldn't be enough to make a worthwhile difference, It's all about keeping oil and oil mist away from the spinning crankshaft.
Thought I read that the LS blocks later got some of these balance holes due to their large main cap/webbing. Pumping losses!
Lower crankcase vacuum also reduces resistance to oil flow through the engine. It also helps reduce windage. The oil also stays cleaner for longer since blow-by gases, water dilution/evaporation, and evaporated light ends from fuel dilution are sucked out of the crankcase.
I have seen a vacuum pump worth up to a 30 HP increase on the engine dyno.
Indicated mean effective pressure
(i.m,e.p.) is the uniform pressure that would be required throughout the power stroke of an engine to do the same amount of work as is done by the varying pressures that are in fact obtained during the stroke. Brake mean effective pressure is the proportion of the indicated mean effective pressure that is available to perform external work at the flywheel. The difference between i.m.e.p. and b.m.e.p. is equal to the mean pressure required to overcome engine friction and to perform the functions of filling and emptying the cylinder and of driving the auxiliaries such as the oil and water pumps, generator and so on. These are generally known as friction and pumping losses.
The indicated horsepower of an engine (i.h.p.) equals the brake horsepower (b.h.p./ plus the friction and pumping .losses.
