Advanced Engineering Tech For the more hardcore LS1TECH residents
The benifit of an "overbalanced" crankshaft
Old Feb 1, 2022 | 07:10 PM
IGN-1A's Avatar
Default The benifit of an "overbalanced" crankshaft
Who here has an Overbalanced Crankshaft ?
Old Feb 1, 2022 | 08:09 PM
To me, there is "balanced", and "unbalanced". Please define "overbalanced" for those of us unfamiliar with the term.
Old Feb 1, 2022 | 08:18 PM
SLOW SEDAN's Avatar
As in lighter pistons and rods with a stock crank at 8000+ RPM, sure!
Old Feb 1, 2022 | 09:04 PM
High end shops will overbalance to allow for oil weight from windage. Pretty common. Lance you have talked about this before I believe, no?
Old Feb 1, 2022 | 10:22 PM
Thank you, Scott! That makes it click!
Old Feb 2, 2022 | 09:17 AM
SLOW SEDAN's Avatar
This came up awhile ago, many still argue if balancing is even worth it considering how many 1000+whp engines have mismatched parts and don't care.
Article from SAM founder:
https://bangshift.com/bangshift1320/...perimentation/
Old Feb 4, 2022 | 08:53 PM
IGN-1A's Avatar
Default Rod Bearing Life
Many here ask about ways to increase "engine life".
The Overbalanced Crankshaft will increase Rod Bearing duration at higher RPM.
Old Feb 5, 2022 | 11:02 PM
LilJayV10's Avatar
I remember Steve Morris did a video on engine balancing a while back and he touched on over/under balancing.
