Advanced Engineering Tech For the more hardcore LS1TECH residents
engine dyno controller
Old Aug 11, 2022 | 04:30 PM
TrendSetter's Avatar
Default engine dyno controller
anyone ever build an engine dyno controller? i am thinking of trying to use a megasquirt or a haltech nexus.
i got my hands on an old superflow all mechanical jobby a couple years ago and have been thinking of trying to get it hooked up and going soon for an ecotec build. i found a guy on GRM that did a little one a few years ago with a couple arduinos but im looking to be able to do real motors up to 1000hp.
discuss
Old Aug 13, 2022 | 11:18 AM
well dang. guess this will end up being a dyno build thread?
its really hard to find documentation and i was too dumb when i bought this thing to check for binders in the guys house and assumed they were with the dyno, so im flying completely blind.
if anyone has a superflow dyno or knows how to set one up id love to ask some questions on the water plumbing.
Old Aug 13, 2022 | 11:27 AM
Keep us posted! Looks interesting...
Old Aug 13, 2022 | 12:35 PM
ddnspider's Avatar
Good stuff! Be fun to see you getting it running.
Old Aug 16, 2022 | 08:35 AM
ok so i took the absorber apart, and im being told that the impeller is no good and needs to be replaced. i got a price from superflow this morning and its..... expensive
Old Aug 16, 2022 | 08:38 AM
so i drew up the impeller real quick and now im 3d printing a half cutaway to test fitment and see about making my own. worst case is i fail and have to buy one.
the reason im told the existing one is no good is the area that holds the seal has corroded away, so the seal is no longer held in the correct place.
im surprised this seal makes such a difference in the function of the dyno, but they are experts and ive never actually used a dyno before so here we go.
Old Aug 16, 2022 | 09:18 AM
MaroonMonsterLS1's Avatar
man I'd machine and press in a bushing for the seal area if that's the only issue
Shouldn't be hard to make
Old Aug 16, 2022 | 12:33 PM
Even if you had to braze/weld up additional material and machine it down, it would seem worth the effort, but I'm no expert either.
Old Aug 16, 2022 | 01:04 PM
1FastBrick's Avatar
It probably only make a difference in that it will leak and the system will no longer be sealed.
If it's that expensive, I would do the same. Turn it down and make a repair sleeve like they do for axles and cranks.
The rest just looks like it needs to be cleaned up.
Old Aug 16, 2022 | 01:46 PM
well my 3d print test worked.
i was not successful in finding the exact replacement seal this thing uses. it appears to be based on a type 6a but the 'seat' piece is much smaller in the absorber than im seeing available. i bought a cheap one on amazon to get my hands on it. i believe since im going to make my own impeller i can adjust the design to accommodate the different seal.
also just ordered some material to make the impeller.
Old Aug 16, 2022 | 01:49 PM
im going to save the old impeller in case my stupid idea to make one from scratch doesnt work. i should be able to do exactly as you suggest once i figure out a way to hold it in my lathe.
Old Aug 16, 2022 | 01:56 PM
After looking a little closer, I think the seal I can’t find might be one the previous owner used that wasnt correct. He did a lot of mods to the dyno over the years.
it looks like the recess on the back side of the impeller is actually supposed to be flat and that recess is where it corroded away from the dissimilar metal of the seal shell
Old Aug 16, 2022 | 07:39 PM
Define expensive. Maybe a few of us can go in together and help you out for dyno time? Just thinking out loud…
Old Aug 17, 2022 | 07:04 AM
its $550. which isnt that bad in the grand scheme of things except i still have an enormous amount of work to get this thing online.
off the cuff what im expecting is about 1300 in water pumps, 1000 for a water tank, 1500-2000 in control electronics. i originally wanted to just make my own but id rather spend my time getting my green wagon back running and building the ecotec i plan to use this dyno for as its first real project. i have the 350 out of my black wagon to use for figuring it all out. im also expecting at least 1000 in misc unexpected hardware. and thats not even closing in the 'dyno space' as a real room with ventilation.
either way, i appreciate people following along and throwing their ideas out but for now im going to keep the funding private in the event this project never actually gets finished.
Old Aug 22, 2022 | 09:40 AM
i heard the seals from superflow are very expensive also so i did a little research and think i found the replacement. it was like $12 on amazon.
i decided to just make my own replacement impeller. i had it duplicated but at the last minute decided to change it to 7 curved blades from 8 straight blades. it has drastically more blade area. i have no idea if thats good or not. worst case i could make one thats the straight blade design
i got distracted this weekend before doing the back side. its all designed and most of the CAM is done, its just a matter of finding the time/motivation to cut it out.
and i still have to figure out how to cut the keyway in it. the hole is tapered so ill have to get creative.
Old Aug 23, 2022 | 10:57 PM
Dian's Avatar
so how will you compensate for the different chacteristics of the impeller? does the software somehow calibrate itself?
Old Aug 24, 2022 | 06:31 AM
there is no existing software. the dyno as i got it was completely mechanical/electromechanical.
the impeller i remade just pumps water from the holding tank below the absorber into the absorber itself.
the way the whole absorber unit is mounted, its allowed to rotate and push against a load cell which measures torque. so the impeller is automatically compensated for in the design of the unit.
theoretically if i was smart enough i could rework the absorber unit itself as well and it would all still work, it just may have a higher or lower maximum torque it can read.
as far as calibration, i havent even thought of that yet. i know i will need to do it by hanging some weight and measuring the output but i havent even begun to consider the details yet.
Old Aug 25, 2022 | 04:54 PM
1FastBrick's Avatar
Looks like it coming along.
Depending on how it needs to be, the slot could be broached or wire EDM cut.
What Kind of knee mill do you Own and what CNC package is on it?
Old Aug 26, 2022 | 07:12 AM
its an old trionics cnc which is either built from or a direct copy of a bridgeport.
a little before i got ahold of it, someone converted it to modern stepper controls and Mach3. i added a touch probe, pendant, touchscreen monitor and some nicer tooling along with cleaning up a few things.
its definitely firm in the hobbiest level of quality but its fun to play with and i almost always prefer making my own parts from scratch over buying things so its been a neat addition to my shop.
Old Aug 26, 2022 | 01:22 PM
1FastBrick's Avatar
I don't know anything about the CNC portion but that looks like the same Taiwan casting alot of other companies use. It's a copy of a Bridgeport.
I have an old Bridgeport knee mill that a customer gave to me when he closed up shop. It's not in the best shape, But it was free and it works for the most part.
I am just getting into and learning about these CNC Retro fit's for manual machine's. They are pretty neat.
