Advanced Engineering Tech For the more hardcore LS1TECH residents
WWII Turbo "tech" for Drag Racers
Old Mar 17, 2023 | 02:30 PM
IGN-1A's Avatar
Default WWII Turbo "tech" for Drag Racers
Hi ALL Drag Racers :
You're in an airplane, being chased AND shot at by a fighter plane.
The best method to escape is to gain altitude.
Your piston engine needs more oxygen at higher altitudes.
Thus NOS or Supercharging is the best method.
A Centrifical Compressor driven by a Turbine works well, one that is NOT connected to the engine exhaust.
I have one of these items and would like to fit it to a drag racing car ?
Old Mar 17, 2023 | 03:39 PM
What does it rely upon, slipstream air??
Old Mar 17, 2023 | 04:19 PM
IGN-1A's Avatar
Hi, the "hot side" turbine has a fuel/oxygen inlet AND a Sparkplug.
The normal exhaust inlet is sealed as in a combustion chamber.
Old Mar 17, 2023 | 04:36 PM
A gas turbine powered supercharger. I would suspect it to be less efficient than a normal turbocharger.
Old Mar 17, 2023 | 05:48 PM
IGN-1A's Avatar
SURE, though there would be NO Exhaust Back Pressure AND no changes to the Exhaust System
Old Mar 17, 2023 | 07:08 PM
And it IS for drag racing, so this is about all-out performance for seconds at a time.
But being on the ragged edge of death during a run, I would expect a fairly sophisticated microprocessor to be required to properly govern this machine at said ragged edge of death.
Old Mar 17, 2023 | 07:31 PM
IGN-1A's Avatar
Default Booost control of a "self powered" compressor
SURE, I have created MY OWN Micros.
My first was to use an HC-11 AND MY OWN HREIC Chip (DIS) that allowed the Gating of Ignition Coils.
The MOST SIMPLE "chip" can operate Fuel/Oxygen MOSFETS used to control Solenoid Injectors.
Thus "boost" control is based on MAP/RPM.
Old Mar 17, 2023 | 11:25 PM
Please explain "gating coils".
Pardon my ignorance.....
Old Mar 18, 2023 | 10:20 AM
bthomas's Avatar
That era of forced induction designs weren’t the most efficient. Most relied on dual charging with a supercharger and a turbo. Supercharger for lower altitude and immediate performance, with the turbo taking over at higher altitudes.
http://rwebs.net/avhistory/opsman/geturbo/geturbo.htm
Old Apr 19, 2023 | 12:38 AM
NSFW's Avatar
One more option to consider, or at least do the math on... Electric supercharger. Basically take a Procharger and drive it with a large electric motor. It would of course need a large battery as well. It would probably weigh more, but maybe not a lot more, and it might be easier to maintain and tune. Might be hard to find a place for the motor though, it won't be small.
I've been playing with "personal electric vehicles" lately (skateboards, bikes, etc) so this seems like a fun intersection of two hobbies.
Assuming it takes 50hp to drive the compressor (wild guess)
50hp = 37kw
Here's motor-controller pair that might work: 45 kW Electric Propulsion System (mgm-compro.com)
Runs at 400v, so maybe go with a single strand of 95 lithium cells in series. (95 cells x 4.2 volts = 399v)
Molicel P42A cells can put out 45 amps, which at 440v would be just under 45kw limit of the motor/controller combo.
Might cost $2k or so for the battery.
Would probably run the compressor for about 4 minutes total, maybe call it twenty 10-second passes to be on the safe side.
Then there's the matter of gearing the motor to the compressor at the right ratio.
It might work.
