Fuel Injector Droplet Size
For the sake of starting discussion, I'm going to say definitively the the smallest droplet size possible is best for maximizing serfuace area and change of state from liquid to gas, hopefully generating perfect homogenisation of the charge mixture. I have nothing scientific to back this up and would love to hear why I am wrong.
All the OE's have gone the way of high pressure direct injection, this would lead me to believe that GENERALLY speaking, smaller droplet size is better on all fronts. I do vaguely recall David Vizard speaking on the topic, there was some situations where it may have been advantageous to have bigger droplet size but from memory it was oddly specific to his Mini race engines.
Install crudely DE-Capped injectors ( Bench grinder ) input 70# for injector flow rate: Truck starts immediately, runs well.
Some VE map adjustments here and there.....
Went from 2 immeasurably tiny micro-pinholes to OPEN PINTLE injectors, with ZERO change in driveability, idle quality, no perceptible change in character..
Test case 2)
Stock 5.3 LM7 with 188,000 miles, OEM 25 pound truck injectors.
Change to Deatschwerks 60# open pintle injectors: input 60# to flow rate, didn't change another thing: Starts right up, drives fine. slight tweaks to PE and BE tables. No change in exhaust smell, idle character, driveability. part thrttle, full throttle, all the same story. Two tiny little microscopic pinhole injectors are functionally equivalent to an OPEN Pintle in idle quality, driveability, cold start, warm up, etc.
simple answer: Open pintle port injection does the job, and atomization across an open intake valve does in practice occur very nicely.
Test case 2)
Hey, just speculation....
anything port injection on any engine that a mere mortal owns, gains or improvement from droplet size will be in the margin of error for however you decide to test it. assuming you are injecting the correct amount of fuel, it will vaporize and absorb the same amount of heat by the time combustion happens whether it absorbs that heat in the plenum, intake runner or the cylinder.
