Things they dont tell you about building a stroker..
SVO 30s (which are more like 36s at 58 psi) are fine (I didn't say optimum) for most strokers. In fact, many people run stock 28s (28s at 58 psi) with no problems but this is really pushing the limits.
Like the March balancer that wouldnt go on straight the last 1/2 inch...took hours and hours..
Z06 PCV assy is $70...valve and some hose...get freakin real..
Comp 1.75 rockers require valve cover clearancing..bosses machined and tray removed.
Dont put balancer on less then .150"...(.170-.090" GM range)...any closer and you hit the oil pump with a double roller..
Got 30psi oil pressure with starter priming
Kooks headers fit like a dream
Bottom line...car is already to fire up and no 90mm TB...been waiting for a month...tell me cars dont suck.
I'll have dyno numbers as soon as the final piece comes in.
Charlie
I am also building a stroker at home with some friends but having a machine shop put together the shortblock and degree the cam.
What was the size of the pistons from Diamond.. dish or dome?
I am trying to keep it simple and after reading some of the hasle people have gone through I am gonna go with Comp's OEM lifters, maybe HS rockers since they are like stock but better, comp timing chain so i wont have to play around with that oil pump BS
You will have the oil pump BS with any double roller because you have to space it out.
Make sure the shop holds the crank forward when the torque the mains (per the GM manual). And of course they are competent enough to degree a cam. Good luck..I wasnt going to trust anyone..looking back I would get one from one of the big names..MTI, AP Eng, More, Keith Kraft...only.
Glad I had my stroker assembled by a shop heh (though when I did heads/cam myself last year.. i put a double timing chain on. and new oil pump.. didn't have any issues .....) You will have the oil pump BS with any double roller because you have to space it out.
I went with custom pistons from Diamond -6cc dish, for 4.040 bore, h-13 tool steal pins which I was told I could throw a 300+ shot on these
with LS6 heads 64cc I think I have about 11.2 compression
