How do NASCAR engines make 750+HP?
You are more right than you know. Remember the crazy old Audi Quattro cars? A lot of that AWD has its origins in a Swiss Military APC that VW helped build. No joke. I forget where I read that. The Group B drivers joke about how it took about 100M from the launch to get any boost. Even the 1000WHP GT42R guys get better spool than that in 2L apps, let alone the relatively small turbos (both compressor and turbine) that WRC cars run nowadays.
There is a very good chance Cup plate engines do NOT use beehive springs. With the new larger restrictor plates for the high drag COT, power and rpm is up considerably. Guess which engine had the most power at Talladega?
Jon
2.2liter read up on it,parts are avilable at chevrolet and book on how 2////hopethis helps the masses[[[
]]] Last edited by lesplay2; Jun 29, 2010 at 07:33 PM.
Lesplay2 i like the ideas of reducing restriction. i think you could achive this with material selection alot easier. for example there are some titamium compersites rods (yes compersites!!) that done need to run big or little end bearings. this is because the coficent is lower than that of the bearing material! lol
as for 1100hp form 2.2ltr, i know of one 4G63 tuner that is looking to push 1750bhp from a 2.0ltr engine! He is running somehttng like 18-1 comp. raito and about 50psi of boost! this is using a stock cylinder head (obliously with work done to it). The guys have a billiet head being designed that should enable them, to push 2000bhp from 2.0ltr. THis would be on par with what F1 engiens of the 80s where running (reputed 1500bhp from a 1.5ltr engine) with greater pumping losses. Also this 2.0ltr engine is running oover 400bhp N/A! he has a VE well over 100%. This engine is achiving a BHP to L similar to a 1000cc bike engine.
]]]Secondly, can you link me to where i can read more about this EVO build please?
As far as how is the power made it is pretty simple. You have to match the fuel burn rate, to the piston speed you are running. This is consistent with every competition engine on the planet.
The build sheet is not trick and the engines are not that expensive $25-50K depending on how extreme you get and how many parts are new or used. HP will range from about 750-850 depending on how good your heads are and how high you want to turn the engine.
Heads flow 425+ CFM ( I flow at 25" ), cams 270* range, / .800+ lift, rockers 1.7-2.2, 750 & 830 carbs ( pretty trick to get more than 1HP per carb cfm ). Intakes are about $5K for a good one. Bryant 3.33 crank, 6.2" Carr rods, CP/Mahle/JE pistons with a dish or whatever to make 12:1 with 40-50cc heads. 2.180 intakes 1.625 exhausts, stainless headers about $5k Set for good ones. Uni-Boring blocks with 50-65mm cam bearings, 4.100-4.200 bores, if you want to get really trick you get a Twisted block if you want to make 850hp range as the cylinders start to distort ad lose ring seal when you get above 800hp ( compacted graphite about +50# ) .
We qualified at Charlotte and Atlanta over 10,000 rpm a couple times with some pretty cool test stuff from PRS and HMS. Those engines were junk after 200 miles.
We were able to get 4 practices and races out of engines held under 8500rpm and they still made 750-800hp.
As far as flat tappet cams they used to be welded stellite, now they are made out of VAR 8620 Billet, pretty funky alloys and treatment to last a race. The big core billets are $1000+ if you buy 50 at a time. Grinding them is a real pain and expensive but there are a couple guys out there really good at it.
I think that is about it, not real trick just a SBC with good parts. The key is matching everything together to get the system to work, but that is a given with any proper race engine.
If you need any parts, hit me with an e-mail.
