How do NASCAR engines make 750+HP?
I know this is a Chevy forum, but we got over 700 RWHP out of.....310 cubic inches using a small block Ford block. We used LBP, Lozano Brothers Porting out of Texas for our engines and they were, as you said, not all that expensive. Around $25k some ten years ago. Lots of details, but nothing really outrageous. 12.5 CR, 8500 redline. Think it's really more about using the right parts and processing them in the right way. I hear they are pushing well over 800 now with the new Trans Am rules.
That said, I am looking to build close to 600 with an LS3, stock bottom end and heads on 91. Looks doable and the engine goes to dyno next month...if I can get the sensor pin outs!
I need:
Cam
Crank
Oil Press
MAP
DBW TB
DBW Pedal
Anybody throw me a bone on those?
BTW- Here a pick of the LS3:
NHRA 500 c.i. Pro Stock big block 2 4 barrel carbs = 3.0 hp/ci and almost 11,000 rpm
Those pro stock engines are the most developed pushrod engine on the planet.
typical 4.700+ bore and 3.55 stroke
Nothing sounds cooler than 500 c.i. at 11,000 rpm going through a clutch and 5 gears
I'm sure cup cars would have more power with roller, so Nascar would probably choke the engines power down, with restrictor plates on all tracks, or something. If the cars just ran factory body panels they wouldn't be as fast, more power + less aero = better driver.
Also note that F1 engines are RPM limited. give them another 2000rpm and the power figures will increase!
Chris.
Chris.
