Fuel Vaporizers and Super Carbs...
The turnip trucks are losing their payload....
http://www.comics.com/creators/speed...6610620309.gif
In short, yes a vaporizer is incredibly efficient and will return the mileage improvement you mention... however, since you cannot load the engine very much running in this condition, it would only be practical for an extremely lightweight vehicle spinning at a little higher RPM than usual.
When I say light-weight and low-load I mean something more like the weight of a motorcycle with an unusually large engine.
University students can make it work, but it's not practical at all for a car.
Just to give you an example of some testing I've done along those lines:
I've increased intake air temp to 150*F going into a wet-flow intake system (both carbureted and TBI) and measured a very significant increase in mileage though no-where near 50%, but more like 12% which is actually huge as far as mileage gains go. The condition is that it only happens during steady-state cruising at highway speed where very little power is needed from the engine. Any other tests besides steady highway cruise and you can actually lose mileage due to the big power loss.
For a vaporizer to work, it requires heat and enough surface area to apply enough heat to keep fuel in a vapor. The side effects are greatly reduced charge density, AND much reduced oxygen content per volume (space taken up by fuel vapor). It's just not practical in a street driven car IMO.
Maybe in the future it will work out better with a different type of fuel.
A fuel with a low flash vaporization and an oxydizer would seem to be a possible solution.
Ah White. I actually figured you might have dived into this one before. My dad actually tried this in the late 60's and increased mileage substantially as well. The system he built however required a constant throttle and the application of a VERY heavy brake pedal until he got on the open road.
LOLI have always wondered why our Big Three could not design a system such as this.
Dare I bring up the oil conspiracy here....
Or did you mean something else....?
Personally I like planting someone in the concrete foundation of a large commercial structure if you want them to disappear.
Oh, and there's a network of old copper mines a few miles north of where I live, some of which are over 14,000 ft deep... flooded with water.
EDIT: J.St.J. is the answer. RJ has all the luck.
I've also read that it may be possible to run a vehicle off water (by separating the Hydrogen and Oxygen...to burn them)...I'll need to find the link for that though. With Gas going as high as it is, there's going to have to be some other options.
