Advanced Engineering Tech For the more hardcore LS1TECH residents
Volumetric Efficienty
Old Apr 6, 2006 | 05:39 PM
383lt1's Avatar
Default Volumetric Efficienty
how is 100% volumetric efficienty obtained
Old Apr 6, 2006 | 06:32 PM
treyZ28's Avatar
with a lot of experience and knowlege...or just boost.
Old Apr 6, 2006 | 09:17 PM
mr2guru's Avatar
With the right port velocity, the right cam overlap, and everything else.... >100% can be achieved N/A.
Old Apr 6, 2006 | 09:45 PM
soundengineer's Avatar
you can achieve it on a stock ls1 cam with just intake changes and some good exhaust...
Old Apr 7, 2006 | 01:16 PM
J-Rod's Avatar
6600 rpm clutch dump of death Administrator
The right question is how is 127% achieved (like the Pro Stockers get)...
Old Apr 7, 2006 | 01:41 PM
treyZ28's Avatar
Lots of racecars top 127. Isn't F1 getting close to 200?
Old Apr 7, 2006 | 01:46 PM
mr2guru's Avatar
By creating enough port velocity that the air will cram itself in even after the cyl is full......
Old Apr 7, 2006 | 01:48 PM
mr2guru's Avatar
yep.... it's pretty amazing that they can make >900hp with 3.0L NA on basically pump gas.
Old Apr 7, 2006 | 01:57 PM
treyZ28's Avatar
its amazing what a few billion dollars can produce, isnt it
Old Apr 7, 2006 | 04:14 PM
gun5l1ng3r's Avatar
Is it really pump gas? I would figure the octane would be a lot higher
Old Apr 7, 2006 | 05:36 PM
Old SStroker's Avatar
F1 BMEP @ power peak is excellent but not really better than ProStock. So F1 is getting similar VE to PS.
FWIW, mr2guru, calculate the torque/cubic inch @ hp peak for :
1) 3.0L(183 cubic inches) V10 with 950 hp @18,500
2) 500 cubic inch V8 with 1400 hp @ 9500
F1 petrol is near pump gas as far as octane, but it has many differences. It's also different for each team.
Old Apr 7, 2006 | 10:15 PM
Armageddon's Avatar
...with cheese.
Creating a Venturi Speeds up air creating a low pressure area. Same principle as a carb. Apply that to port velocity and wallah!
