Lightest Rotating Weight 4" stroker combo?
Scat makes a light weight LS1 stroker crank.
I Beam rods are lighter than H Beam rods (6.125 length).
OEM LS7 Titanium rods (6.064 length) sound cool but will they work in a LS1 402 engine? I know downsized (smaller 4.00" bore) LS7 style custom pistons would be needed.
After that, first place your wallet on the scale. Lots of piston blanks come in LS1 sizes. A custom 1" compression height 4.03" piston would weigh under 370gms. You could use a 2.25" pin. Even a 2" pin. You could also use a .866" pin. Reducing pin weight to maybe 80-90gms. You could use thinner rings....043/.043/3mm. A few more gms.
Rods are a different issue. GM Ti rods are probably less expensive than aftermarket. However, the 1" compression height piston will need a 6.2 rod. Custom Ti rods are something like $3-4k. They would probably weigh around 400gms. Custom steel rods, using 1.88 or 1.771 journals, maybe the smaller pin, in a design like the Crower Maxilight that takes advantage of the smaller sizes, would probably be in the 550-600gm weight range for a 500-600hp power range.
Of course the small journals will require a custom crank...maybe $2500-3000.
Unless you are going to spin the heck out of it, why would you do this?
It doesn't take much power to maintain a vehicle at a steady speed.
I wonder what a dyno graph would look like if we held the motor at
3000 RPM? Hmmmm... I'd say a flat power line with a fairly low power value!
Generally, the total energy in the piston/rods is pretty constant at a fixed speed. As one piston accelerates another is going in the opposite direction.
Bret, have you seen more than 5lbf-ft difference between light and heavy components? Say 350gm pistons and 550gm rods vs. 500gm pistons and 700gm rods?
Lighter rods and pistons mean you stress the crankshaft less, at the same piston g's, so you can run the bottom end to a higher RPM. At the same time that lower bobweight can also help you take more material off the crankshaft counterweights and you can lower the inertia of the setup as well. That's where you get the performance advantage, in the lower inertia and increased acceleration rate of the motor.
If you look at a stock LS1 bottom end, 610g rods, 450g pistons, 160g pins etc... your around 1800g bobweights, racing applications can get that down a huge amount, 30% or more.
Bret
However, it only has a token effect on inertia...unless you have empirical evidence that it does. Maybe 2 to 5 lbf-ft of torque.
Now, as for a super light crank. They are out there. you can take one of the forgings that is out, and have the throws re-done to take weight out, or you can go with something like a HTC or Callies. Both can do very light cranks.
I have a friend with a 45 lb Ls1 crank. But the issue is he went with a heavy steel rod to handle the power levels he makes. That in turns means a TON of mallory metal to get the balance right. So, you have to balance the reciprocating mass agaist what you are doing with the crank.
As for an AL rod. You might look at a Jager transformed AL rod. Same strength as steel (or better), not the replacement factor of regular AL (same life as a steel rod), same basic price (probably $1400 set), and about a 400gr rod that'll take 2000HP.
Less weight always equals good. Look at a forged 346 vs a stock cast 346. The stock 346 will usually make about 5-10 HP more just based on the increased weight of the components.
Rotating mass (spinning things like flywheel and crank) effects accelleration. You won't see it on a dyno, but you'll see it on the track.
Here's some math, just for fun. It's been a while since my last physics class, so someone correct me if I missed something.
An engine with a 9cm stroke (3.54 inches), 14.4kg recipricating mass (1.8kg per cylinder for pistion, rod, pin * 8 cylinders), and rotating at 6,000 rmp or 100 rotations per second is using 12.4hp just to make the pistons move, not counting friction. If you manage to reduce the recipricating mass by 30%, that would return 3.7hp to you.
3.7hp isn't much for the price you pay for low weight engine parts, but the real value comes from being able to rev your engine faster if ALL your parts are low weight / strength.
Below is my math; again, I may have missed something.
Basic equations:
P = E / T
E = F * D
F = M * A
A = 2 * D / T^2
Putting it all together:
P = F * D / T
P = M * A * D / T
P = M * 2 * D / T^2 * D / T
P = 2 * M * D^2 / T^3
P = 2 * M * D^2
D = stroke * rotations * 2
Final equation:
P = 8 * M * stroke^2 * rotations^2
P = 8 * 14.4kg * 0.09m^2 * 100^2
P = 9.3kw = 12.4hp
0.3 * 12.4hp = 3.7hp
Bret
Great article about this by David Vizard in the Feb O6 Pop Hot Rodding. pg 86.
One of the best ways to comprehend the difference is look at a chassis dyno pull from a dynojet in 1st and 4th gears. The more you lighten the crank, flywheel etc... the closer those two curves come within each other.
Bret
now as far as i can see this is aplicable for all engines!
and a very good point H8 LUZN!
thanks Chris.
