What Is The Effect Of Different Lifter Wheel Diameters
How does the different roller size affect cam timing? Do the larger rollers need large base circles?
What is a reference for this?
on the ramp slightly faster on opening and later on closing giving the valve a
touch more duration.
That's what it seems like on paper, and I don't imagine the duration to change
much between those sizes.
Does the larger wheel also reduce side loads on the lifter? Are side loads on the lifter an issue?
A larger wheel wont reduce side loads, but it may reduce the stresses from side loading as the load is spread out over a greater area. Generally, the larger the wheel, the lower the hertzian stress on the lobe- which can allow a slightly more aggressive profile for a given stress.
Al
I would say when you are doing real endurance engines or extreme drag race stuff you should always do these lifters if you can afford them. You probably "need" to over them in the 9000+ rpm range and 1.000 inch lift stuff as well as 400+ PSI seat pressure and 1000+ open. These big lifters with bigger wheels also require different cams, sometimes also with narrowed lobes so you don't operate more lifters than you intend to!
I have used regular good quality .842 roller lifters like the Isky Red-Zones or Morels with .750 wheels even around 350 PSI on the seat and 850 PSI open but I would sure rather have beefier stuff like the .904 or the .935 lifters that Al is talking about! That type of pressure will even take out regular .842 lifters sometimes. Like everyone always says "the valvetrain is not a place to save money!"
I use a software program called "Doctor Doctor" to test camshaft profiles using different wheel diameters, rocker arm ratios. This is a great program for checking quality of grind as well.
There is a really good book available on camshaft design by Don Hubbard: "The Camshaft Reference Manual". Don provides some useful software with the book. You can order direct from Don:
dhubbard7@earthlink.net, Phone 239-936-0866, Fax 239-275-9936.
I'm not sure what the current price is. I paid $149 back in 2000 for it. This book is worth many times that price.
Steve
Steve Demirjian
Race Engine Development
Oceanside, Ca.
760-630-0450
web: www.raceenginedevelopment.com/
e-mail: race-engine-development@***.net
