Advanced Engineering Tech For the more hardcore LS1TECH residents
Nice intake manifold... - The ITB thread
Old Sep 1, 2006 | 09:23 AM
J-Rod's Avatar
6600 rpm clutch dump of death Administrator
Here are some videos I've posted before.
242/242 106 LSA 106 ICL in 346 with ITB setup that Sam of Sam's Performance in Sydney fabricated. Sam also tuned this car in SD. Keep in mind this was a few years ago before the Harrop hit the mainstream.
http://users3.ev1.net/~black_ops/video/242-106.mpg
Nathan's Ute.
(right click, save as)
http://users3.ev1.net/~black_ops/AUS...02_higgins.avi
Old Sep 1, 2006 | 10:21 AM
slimcracka's Avatar
second link dont work..but a badass intake..
Old Sep 1, 2006 | 10:45 AM
J-Rod's Avatar
fixed link
Old Sep 1, 2006 | 12:41 PM
Ryan@ABear's Avatar
Those are sweet.
Right-click, set as background.
Old Sep 1, 2006 | 03:23 PM
CATransam's Avatar
this was a supprise, as was the idle with that monster cam
Old Sep 6, 2006 | 06:41 PM
Beaflag VonRathburg's Avatar
OWN3D BY MY PROF!
http://users3.ev1.net/~black_ops/AUS/dsc00037.jpg
J-Rod, who makes this intake manifold?
Old Sep 6, 2006 | 10:08 PM
Phoenix 5.7's Avatar
how much boost can the Harrop take? particulary the black part, cause im assuming the ITB part can take pretty much anything pushed through. im having very interesting ideas of a Warhawk LS7 block, LS7X heads, ITB intake(probably Harrop) being boosted by twin Rotrex superchargers, with a nice direct port nitrous setup. all the best newest parts coming to the LSX market.
Old Sep 6, 2006 | 11:03 PM
Beast96Z's Avatar
The air boxes are for ****. If you buy a Harrop, the air box portion should be left in Aussie. Adding those boxes puts the performance of the intake back in line with a FAST 90. Even the guy at Harrop talked about how much they killed the power. I ordered mine with no air box and no plate that holds the air box. After I check fitment in the F-body chasis, I'll work on filtering the air. Here's a pic of it without the rif-raf.
Old Sep 6, 2006 | 11:09 PM
WhiteStripes's Avatar
Wow, all very fine pieces of work. I'm in awe. I've never seen anything like those before.
Old Sep 7, 2006 | 12:39 AM
ultraz's Avatar
kinda viperish
Old Sep 7, 2006 | 10:14 AM
J-Rod's Avatar
Sam at Sam's Performance built them. Now he buys the Harrop unit as it is just a lot easier than building stuff himself.
If you went with a Supercharger, then you don't need an ITB intake. You can use a shared plenum as the supercharger will fill the plenum for you.
Old Sep 7, 2006 | 11:50 AM
  #32
Beast96Z's Avatar
Old Sep 8, 2006 | 10:43 AM
  #33
FieroZ34's Avatar
The first thing I'd do is cut the velocity stacks off and weld on ones with a halfway decent shape and taper angle.
The second thing would be to get rid of the parts store fuel line. Common, worm clamps? Fix that!
Old Sep 8, 2006 | 12:22 PM
  #34
383ss's Avatar
any idea if Harrop plans to make one compatible with L92 or LS7 heads?
Old Sep 8, 2006 | 04:32 PM
  #35
Beast96Z's Avatar
The stacks are tapered, but it's hard to tell from the pic. They may not be the most dramatic, but tapered non the less. The fuel line is already gone.
Old Sep 8, 2006 | 06:52 PM
  #36
FieroZ34's Avatar
My mistake, points for Harrop. Tapering is a good factor when it can be applied (And custom ITBs offer the perfect opportunity for this). Sportbikes taper their entire intake tract STOCK.
My ITB's bores are straight, but the velocity stacks are at least tapered (My stacks bolt-on, so i can switch to longer/shorter as well).
Good job on the fuel lines. Some nice stainless braided AN line would look awesome. Also, nice intake. Be proud to show that off. Make the install look good, and put up some pics!
Old Sep 8, 2006 | 09:25 PM
  #37
Beast96Z's Avatar
It has a -8an stainless feed, -8an stainless crossover and a -6an stainless return w/aeromotive regulator. The lines that are on in the pic came on the intake from Harrop. There set-up to plug n play with the stock fuel lines.
Old Sep 8, 2006 | 11:02 PM
  #38
I'm going to assume these intakes are for incredibly high flowing N/A big blocks?
Old Sep 8, 2006 | 11:48 PM
  #39
FieroZ34's Avatar
Not at all. I'll be running ITBs on my relatively small displacement V6 (3.4). ITBs can be tuned for engines of any displacement, though, generally, unless you are turning some high RPMs, smaller displacement engines typically need smaller blades/runners. Also, ITB motors respond really well to turbochargers. I've heard the response is amazing with them.
Old Sep 9, 2006 | 05:50 AM
  #40
manolis's Avatar
Default It is for a modified Honda and not an LSx, nevertheless it shows the way.
An ITB without throttle valves inside, for extreme flow capacity.
The intake valves do the throttling.
The engine works from 300 rpm to 9000 rpm.
More cheap than anything known (zero cost).
Initially the original plenum was left untouched, only the throttle valve was thrown away:
Then the plenum was sliced to result an efficient ITB
And removing the air filter
Just after cutting
Applying the pushrod VVA on an LSx engine, see relevant thread, a cheap trumpet set can easily overflow any ITB.
For more: http://www.pattakon.com
Manolis Pattakos
