Advanced Engineering Tech For the more hardcore LS1TECH residents
carbed and efi cams, same or different?
Old Jan 21, 2007 | 04:09 PM
chevydad's Avatar
Default carbed and efi cams, same or different?
is there a difference between a came for a efi motor and one for a carbed motor? like would a t-rex or similar cam work well in a lq4 with a carb and victor jr intake?
Old Jan 21, 2007 | 06:16 PM
Ed Wright's Avatar
9-Second Club
I don't see whay they would be different.
Old Jan 21, 2007 | 07:01 PM
Patrick G's Avatar
LS1 Tech Administrator
A carburetor doesn't necessarily require any different LSA than EFI, but a different style intake may. A single plane intake with unequal length short runners is going to want different valve events than running a FAST intake.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
Old Jan 21, 2007 | 09:30 PM
ChucksZ06's Avatar
They will both work but the engine can be made to run smoother at all rpms with efi vs a carburator. With a camshaft with lots of overlap the engine does not have a good signal to the carb(low vaccum) and the vacumm is what pulls the fuel out of the carb into the intake...with efi you can give the engine the best a/f ration at any given rpms...hence smoother idle and midrange than a carb as well as better economy.
Old Jan 21, 2007 | 09:37 PM
mrdragster1970's Avatar
6 & 8 Second Club
I was thinking along the same lines ^^ the signal to the carb is very important.
I would ask an expert if you're going for max HP.
Old Jan 23, 2007 | 08:34 AM
chevydad's Avatar
so what your saying is they're the same.
Old Jan 23, 2007 | 11:18 AM
Nine Ball's Avatar
LS1Tech Co-Founder
should be the same. As long as the proper A/F mix is reached by the combustion chamber, that is all that matters between EFI and carb.
Old Jan 23, 2007 | 12:25 PM
andereck's Avatar
Well how about this, an efi cam in a carbureted vehicle will run fine and generally have excellent driveabily and sacrifice some performance in the upper rpm ranges and way down low off idle. A carb combination specific performance cam would generally be considered too rowdy for most long runner efi engines.
 Michael S. Palmer
Old Jan 25, 2007 | 04:08 PM
chevydad's Avatar
why would a carb sacrifice power down low and up high compared to efi?
Old Jan 25, 2007 | 04:10 PM
chevydad's Avatar
is there a formula to figure out what vacuum will be on a a certain motor a cam.
Old Jan 25, 2007 | 05:16 PM
andereck's Avatar
Carbureted intake manifolds generally have shorter runners than efi with the exception being an LT1. Long runner intakes are where efi has the advantage. You just couldn't have a long runner manifold on a carbed road car. Some efi manifolds have over 19" of runner length. The longer the runner the lower its resonant frequency. When a runner resonates it creates pulses that help fill the cylinder. Longer runner manifolds help to make more torque at a lower rpm.
If you heat the fuel or intake charge of a carbed engine, such as GM's heated element carb gaskets you gain many of the driveability and economy advantages of efi, but not to the full effect.
Old Jan 25, 2007 | 10:15 PM
airflowdevelop's Avatar
Most of the EFI grinds that we run in class cars would never work with a conventional carb due to the lack of signaling. It is worth less than 2 percent though.
Dennis
Old Jan 30, 2007 | 08:02 AM
chevydad's Avatar
a cam with a lsa of 110 will produce more vacuum than one with a 112 0r 113? or does overlap effect vacuum more than lsa?
Old Jan 30, 2007 | 08:22 AM
thehammer69's Avatar
Overlap can be adjusted by LSA...and the more overlap, the worse the vacuum at low rpms.
Hammer
Old Jan 30, 2007 | 09:53 AM
V6 Bird's Avatar
They are different, but like stated not by much. 2% I can agree with.
