Head porting question.
a Variac (variable autotransformer, check the
local electronics surplus places; I have at least
three from yard sales). The other is to get a
dimmer switch, if you can find one that's also
rated for ceiling fan speed control that would be
good but I have run the grinder off a "plain old"
with no trouble. Put it in a metal 2-gang work
box with a pair of sockets and a switch + socket
cover, all out of the electrical supplies junk tote.
I think the dimmer one seems to "cog" more at
low speed setting than the transformer, which
seems smoother. But either ought to work.
what did you (whoever) use for a template, and
how far is too far? I am envisioning going with a
Professional Products 85mm TB/intake some time
later and would like to pre-port-match to that so
as not to take the heads off once done. I guess
maybe they'd sell me a gasket to use. Wondering
if anyone knows about the stock O-ring vs PP
paper gaskets and the range of manifold port sizes
and shapes out there. How much slop to allow for
manifold variation etc.?
mani's that I'll be working on and I'll use the same gasket so they
will be closely matched with the heads.
I think it is better to be more conservative of the port size on the
intake mani than on the intake port of the head. I think if the port
on the intake mani is too big, the gasket will disrupt the flow. And
if the port on the head is slightly larger than the gasket, you might
lose some velocity but it wouldn't cause much if any flow disruption.
Maybe that makes sense. Someone please correct me if I'm wrong.
Oh yeah, I was able to reach the rest of the short side by flipping
a cartridge roll. thanks
Two differn't 4.6 4v heads both expected to make over 1000 rwhp...
Xrated billet e85 project..
TT 302 4v
For the SSR I use a 3/8th round file, often. Its easy to control in weird positions.
heres some pics and info that might help you, one set of L67 3800 heads I did. Very budget DIY setup, lots of stock parts. Gen3 M90 no spray, went 11.4 in my GTP at 3250#s
http://www.clubgp.com/newforum/fb.as...anguage=single
