Advantage of high-flow heads?
Thanks!
If your intake can only flow 300CFM, there's no point to getting heads that flow 340, because they'll only flow 300, due to the intake.
In theory, I'd agree with that, but in practice, we've seen gains from getting heads that flow better than your intake does. I guess it's got something to do with if you're pushing the limits of the head's flow or not. I.E., a head that flows 340 will flow 300 easier than a head that flows 300 max.
Am I completely wrong?
However for the point we are making, is often the 340 head will flow more at each lift point below .500" than the 300 head.
So the cam is more effective at each lift.
However if the system flows LESS with the bigger head, you'll make less power.
Thats how it really works.
Also, yes, the head loss at peak flow is more with worse ports. A large tube with a little bit smaller choke point placed anywhere will flow more than a tube that's equal diameter as the smaller choke point, assuming it's not actually choked (see first paragraph).
Also I would add one additional point, you would be able to get the most out of those heads with an intake valve timing to match the flow rate vice the intake. You could get up with a cam guru, which I am not and he would be able to match you a cam to get the most out of your heads with the intake combo.
