Advanced Engineering Tech For the more hardcore LS1TECH residents
Soild Roller Lsx down on power
Old Jun 29, 2007 | 11:06 AM
GrannySShifting's Avatar
yeah, for the record, if someone from a centrally located fbody shop, has ever touched your car... dont be surprised if you have two drivers side coil pack harnesses when you go to relocate the coils and extend the harnesses.
I thought I was getting it done when I could copy the pass from the drivers Id be doen in no time.... who knew GM had different harness for each side and I shoudl do the opposite of what the book says lol
Old Jun 29, 2007 | 01:05 PM
ShiznityZ28's Avatar
The harnesses can't be different. we swaped the hole side left to right plenty of times.
Old Jun 29, 2007 | 02:52 PM
SSPerformance's Avatar
howd you manage to not have those firing? did you rewire something?
nope guys at thunder said there is only like 5 copper strans in there and they dont like to be handeld im gona check for voltage in a min
Old Jun 29, 2007 | 06:01 PM
all the injector wires r fine with the noid light and mesure 9.2 volts even changed the injectors around side to side no diff coil is fine and its geting 13.5 volts checked the plug wires for resistance and there all fine... even thought the way the fuel rail was setup it wasent geting any fule changed that no diff... every cylinder is 250ish now and the #2 is 190-200ish looks like i will be doing a leak down test and if that checks out fine i will double check my timing gears
Old Jun 30, 2007 | 04:09 PM
rings r shot the motor looses 100psi in 15 seconds. took the rockers of so i put the valve covers back on and so the filler neck whould be th eonly place for the air to go it builds enought presure to wana blow ur hand off it if u hold it over it..... Second motor from HK that has had problem i will be shoping else where now
Old Jun 30, 2007 | 04:47 PM
Yeah thats it.... not likely. ABout as likely as the last motor you had from him failing after "just being ran on the motor" but the ring lands had more waves than a hawaii beach. Weve hit his motors with a 300+ shot on nitrous and pistons tops looks brand new.
Any chance it was ranthat rich and washed the cyl down... like if the valves were too tight and hanging somethign open and a cyl wasnt popping off right?
Old Jun 30, 2007 | 05:38 PM
i set the valves exactly like he said car went direct to eastside and the a.f wasent far off when it got there. and yes the first motor was ran on all motor from him. time to buy a new LSX block and go big...
Old Jun 30, 2007 | 05:56 PM
JL ws-6's Avatar
Race your car!
why not just have that motor re-ring'd and run it, at least for this year? It's a good piece with the heads and all that you have going on with it..... be a hell of alot cheaper, and would let ya get back to racing somewhat quickly.
Give ken a call, see what he says..... Id' do that before going crazy spending 20 grand.
Old Jun 30, 2007 | 06:12 PM
racer7088's Avatar
Arrow
Charlie, You melted down your first set of pistons and knocked off half the moly of the top rings. The engine was SEVERELY detonated and most of the pistons burned up, melted. Brian at Wiseco also saw them and what happened. They looked worse than the same pistons (K394A3) that people here on LS1Tech run 300 shots on. These same pistons after leaning out or detonating real bad still don't even usually have that much damage and yet this was on an NA engine supposedly. There was molten aluminum at the tops of most of the bores that we had to rehone to even put the new pistons in. We have never seen an NA engine even do that to tell you the truth and neither had anyone else I forwarded your piston pics to. They all assumed a massive lean out, excessive timing or NOS usage and failure.
Now on your current setup I have no idea what it wrong as I only sold you some parts and other people put it all together and set it up and tuned it but it might be something simple so look at that first like these guys are telling you. I never received your dyno sheet on the fax but seeing it now in this thread it's hard to tell much with the big converter and T400 as the results are always kind of scewed and weird to look at on automatic dyno sheets without locked converters. I would look for signs of valve float or fuel shortage etc. but you don't exactly crash anywhere on your sheet up there. We do the same sort of things down here with no problems but again I am not there to really know what is going on.
Old Jun 30, 2007 | 06:34 PM
motor has alot blow bye i noticed i just though it was cuz u set it up loose for future n2o use but i guess the rings r shot/ never right to start with.
Old Jun 30, 2007 | 06:44 PM
racer7088's Avatar
Exclamation
Charlie,
You have ring gaps. Your cylinders won't "hold pressure" for 15 seconds! They immediately leak which is why you have to have air pressure to even do a leakdown test. There's nothing wrong with your rings unless you've fried something which hopefully hasn't already happened again. Was it tuned at the same place again that fried your original pistons?
After doing literally hundreds of these engines you are sure having lot's of problems. You may simply not be making big power with that intake as well. I have not personally used that manifold but of course we all know the ET heads can make big power even well into the 7xx RWHP range NA. If that intake is unported or has a restrictive elbow etc. who knows? Are you even getting full KPA etc?
I do engines for over 8 shops here on LS1Tech and yet don't seem to have these situations really ever and when I say that I am talking from really big power adders to small heads / cam 347s. Pistons and rings just don't "go bad" from what I've seen over the years.
Old Jun 30, 2007 | 07:04 PM
  #32
racer7088's Avatar
Arrow
I think the power you are looking for is probably elsewhere Charlie. Where is the cam in the motor as far as ICL?
I have to go out now but I would check that first if you pnly had 150 PSI cranking pressure.
Old Jun 30, 2007 | 07:57 PM
  #33
cam was never dergeed
Old Jun 30, 2007 | 09:47 PM
  #34
ATVracr's Avatar
You cant just assume that they ground it exactly like you ordered it.
All that high dollar stuff and you dont degree the cam in ...
Old Jun 30, 2007 | 09:54 PM
  #35
gona check the cam tomorrow for any messed up lobes and degree it a few people told me that not degreeing it is mostlikley not the major problem
Old Jun 30, 2007 | 10:06 PM
  #36
edcmat-l1's Avatar
Motors probably fine. Too much converter. Soakin up the HP on the dyno, makin it look like its nosin over.
You said the trap speed was 129. what was the RPMs thru the traps?
Also, you're not doin the leakdown test correctly. You have to use the proper tool, a dual gauge setup. Set the one gauge at 100 psi even, with it hooked up to the cylinder. The other gauge will show you the percentage of leakdown.
Data log it on the dyno, to make sure it doesnt build vacuum at the end of the pull, which would indicate an intake restriction. The MAP should stay right at 100 kpa or very near.
Old Jun 30, 2007 | 10:11 PM
  #37
7k im trapin the car shouldent fall off on power at 6600rpms tho....
Old Jul 1, 2007 | 05:43 PM
  #38
pulled the cam today everything was perfect gona barrow a leak down tester and do a leak down test tomorrow
Old Jul 2, 2007 | 06:22 AM
  #39
edcmat-l1's Avatar
With a 5200 RPM converter, its gonna fall off (up top) on a chassis dyno.
You cant lock it, so you've still got all that slop in the high rpms.
Old Jul 2, 2007 | 06:36 AM
  #40
still dose not explain the loss of hp and mph
