Advanced Engineering Tech For the more hardcore LS1TECH residents
Soild Roller Lsx down on power
Old Jun 26, 2007 | 10:02 PM
SSPerformance's Avatar
Default Soild Roller Lsx down on power
Here The setup
etp 245 heads
Vic jr with an elbow
Lq9 412ci give or take 2 cubes for get exact bore
12.5 to 1 comp
266/268 680/690 lift soild roller
Jessel Rockers
th-400 with a 5200 Extream Converter Concepts
had the car a few time to the track go the converter problem fixed threw it back on the dyno to see why its only traping 129 in a 3350 race weight car. First thought i had the valve adjusted to tight .006 on the intake .008 on the exhaust. talk to Erik from hk and he told me that isent where the power was being lost. car only made 440sae rwhp @ 6600 rpms then starts falling. this car should pull to at least 7300... i adjusted the valves @ .016 now and .018 dont think it made a huge diff but worth a try....im just outa ideas and geting fed up with the car.....did a comp test and every cly was 155-158 across the board
Old Jun 26, 2007 | 10:15 PM
tuff's Avatar
8 SEC SLOPPY SHOT!!!
Maybe your tune is off.Do you take data on a pass with a wideband?
Old Jun 26, 2007 | 10:18 PM
east side tuned the car and its 12.5 across the board a lil rich but nothign to kill that kinda power
Old Jun 26, 2007 | 10:27 PM
Beaflag VonRathburg's Avatar
OWN3D BY MY PROF!
Could be something drivetrain wise. Pushrods rubbing, valve float, etc.... Have a dyno graph we could look at?
Old Jun 27, 2007 | 10:06 AM
GrannySShifting's Avatar
this should probably be in internal engine, not really adv tech
our 400 inch hyd cam setups have no problem going to 77-8200 rpm, look at the top end somewhere. Who picked the cam/springs/valvetrain and assembly?
Your definitely down 5 mph from our hyd stuff and should be a few more on top of that with solid roller and that compression. Im guessing you were expecting 138 mph traps or so?
Old Jun 27, 2007 | 02:52 PM
erik from HK set up everything from cam to springs and all
Old Jun 27, 2007 | 03:06 PM
Old Jun 27, 2007 | 04:14 PM
valvetrain doesnt look like its crashing, looks to me like its something outside the basic mechanicals its not happy with.
Old Jun 27, 2007 | 05:20 PM
any ideas on where to start looking?
Old Jun 27, 2007 | 05:48 PM
turbo'd stang's Avatar
All the plugs look good?
Old Jun 27, 2007 | 06:30 PM
WOTFMAN's Avatar
The compression psi is weak. You definitely have something wrong. with 12.5:1 you should be seeing easily 220 psi.
Rings washed out...etc.
Get me your phone number via PM and I can get you in touch with someone that can diagnose your problem. Need more info on valvesprings, retainers, etc.
Old Jun 27, 2007 | 06:55 PM
all plugs looked good ...rings r gaped for a large amount of n2o use for future plans.....i read with cams with larage overlaps that the compression test will be low like that
Old Jun 28, 2007 | 11:53 AM
JL ws-6's Avatar
Race your car!
Does the motor have an adjustable timing set on it? Any chance the cam sproket could have shifted messing with the cam advance or something?
Old Jun 28, 2007 | 12:44 PM
Haans249's Avatar
I agree with WOTFMAN, the compression does seem quite low. Even with that big of a cam, with a 12.5:1 compression, you should be seeing at a minimum 185-190psi and thats stretching it. You should try a leak down test on all cylinders.
Old Jun 28, 2007 | 02:53 PM
im leaning towards and injector/ broken injector wire gona check header primary temps tonight and then a noid light if i find anything
Old Jun 28, 2007 | 07:32 PM
got a good idea where the problem is put the temp light on and the hole left bank is all in the high 250s the right bank is the high 190 low 200 except the # 8 cyl wich is in the 250s.... thought maybee my 2 step box was screrwed up and unhooked it no diff.... gona have to get the noid light out tomorow and check the coils to
Old Jun 28, 2007 | 10:48 PM
67Ranger's Avatar
it really seems like those heads should carry the power a lot further as well. also if erik set up the valvetrain it should be right, but you might want to check the cam and make sure it isnt off a few degrees.
Old Jun 29, 2007 | 06:38 AM
read the last post 2 , 4 ,6 arent fully firing
Old Jun 29, 2007 | 10:02 AM
howd you manage to not have those firing? did you rewire something?
Old Jun 29, 2007 | 10:51 AM
ATVracr's Avatar
You know all about that dont ya.
