Advanced Engineering Tech For the more hardcore LS1TECH residents
Spring psi question?
Old Apr 21, 2008 | 02:34 PM
JS's Avatar
JS
Default Spring psi question?
We have a 236-242 617-613 112+2 sitting here waiting to go into a 402
The springs we are using are PSI 1511-ML's rated to .625
Now they rate the spring at a install height
1.800@120PSI for .625 lift
The lobes on this cam are XFI which I was told were alittle easier on the VT than the XER's so I figure the 1.800@120 is fine but would u shim this spring .010/.020 to bump the spring psi up to say 140 with this lobe?
PSI told me 1.800@120 would be fine with this cam and this is the manufatures recomendation but I just would like to be sure so thats why I'm asking for some info.
Persay some engine builders or from head builders on here or just one of u big brains etc...
Old Apr 21, 2008 | 10:12 PM
405HP_Z06's Avatar
Which heads/valves and rockers arms?
Old Apr 22, 2008 | 05:33 PM
JS's Avatar
JS
Dart 225's (2.05/1.60)
Stock rockers..
Old Apr 22, 2008 | 05:47 PM
blackz93's Avatar
Where does the spring coil bind?
Old Apr 23, 2008 | 01:22 AM
405HP_Z06's Avatar
The published coil bind spec is 1.100" and the published specifications for seat pressure is 130 lbs. @ 1.800". Shimming these to a 1.780" installed height would put you right at the minimum safe coil clearance and give you the following:
With the additional valve train weight, it's not a bad idea to install these at 1.780".
Old Apr 23, 2008 | 10:01 AM
JS's Avatar
JS
I think I might try a .010 shim for 1.79@130ish for the added weight of the valves
Thanks...
Old Apr 24, 2008 | 12:51 PM
blackz93's Avatar
I'd probably go with 1.780.
Old Apr 24, 2008 | 03:17 PM
Alan@XHP's Avatar
Closed ex-Sponsor Account
First off, I would measure and check the installed height of every spring pocket. Sometimes you will find a pocket that varies from the rest which could cause an issue. It is also hard to find .010 shims, the industry standards are .015, .030, .060. Just be careful running the springs at minimum clearance (.060) from coil bind.
Old Apr 25, 2008 | 12:58 AM
405HP_Z06's Avatar
Isky offers a very nice 'micro shim kit' that works perfect for the LS motors. Designed for us **** types that like things to be as close as possible.
Old Apr 26, 2008 | 01:10 PM
JS's Avatar
JS
I've seen that Isky kit before too
TalonWS6 is checking every pocket
We're setting them up at 1.79@130ish.
This will give me plenty of coil bind.
Thanks for the help guys...
Old May 3, 2008 | 08:21 AM
Randy WS6's Avatar
Who carrys the ISKY #6 shim kit ???? I need a set of the now.
Old May 3, 2008 | 11:17 AM
405HP_Z06's Avatar
Isky or Summit Racing :http://store.summitracing.com/egnsea...nresults=false
Old May 3, 2008 | 09:20 PM
Randy WS6's Avatar
Looks like there back ordered till the 15th
Old May 5, 2008 | 04:24 PM
JS's Avatar
JS
Well I checked all the pressures..
They were ALL off so if u guys buy these heads I would check them.
They had 2 shims under each spring which made them all 1.76@155+ and this could cause coil bind on my 615 lift setup..
TalonWS6 played around with the shims and found 1.80@145 to be perfect.
We expect to lose 10lbs after a few heat cycles and dyno runs.
We feel this to be the best setup for our cam specs.
U might find u need more or less but be careful with coil bind..I believe 1.80@135 will be the final results after breakin and than supports .625 lift with plenty of could bind to spare.
If u are getting these heads again just make sure u CHECK THEM
The valvejob and bowl porting looked excellent from Dart.
This is one killer out of the box head for under $1600.
Old May 5, 2008 | 11:50 PM
405HP_Z06's Avatar
Originally Posted by JS
Well I checked all the pressures..They were ALL off so if u guys buy these heads I would check them.
Good info and wise advice. My Dart 225's, stock from Dart, were all setup at 1.800", with none of the installed heights varying more than .005". I guess I got lucky......
I agree, the Darts are a very nice head.
