Advanced Engineering Tech For the more hardcore LS1TECH residents
Block Lightening
Old Jun 17, 2008 | 12:45 AM
bluecamaroz28's Avatar
Default Block Lightening
Anyone tried that?
Pros & Cons?
Does it worth it?
I should say by CNC machining.
Old Jun 17, 2008 | 01:32 AM
mrdragster1970's Avatar
6 & 8 Second Club
Not worth it. If you have the time, grind off all the little tabs & casting crap.
Smooth the valley for better oil flow, and do something else. Not worth designing program for a few lbs.
Old Jun 19, 2008 | 10:46 PM
The Dark Side of Wil's Avatar
Ditto not worth it, but for different reasons.
GM engineered the block with just enough mass to hit their reliability targets at stock power levels and with production casting technology (wall thickness vs core shift). If you start upping the power a lot, you're already reducing the engine's reliability. If you start carving metal off the block at the same time, you're REALLY reducing the engine's reliability.
Notice that all the aftermarket blocks and heads are HEAVIER than stock parts because of reinforced deck surfaces, thicker main webbing, extra head bolt bosses and a host of other changes to increase the DURABILITY of the engine.
Lighter is a direction you can go ONLY when you can sacrifice durability.
Old Jun 24, 2008 | 09:26 AM
XtraCajunSS's Avatar
Callies offers CNC Block Lightening. It makes sense if you are using an extra heavy LSX block or an aftermarket block that may be engineered for 2500+HP. If you are building a max effort N/A motor, you may not need all the extra material. Also, when using motor plates you don't need the motor mount bosses. Basically you can remove any unnecessary material from the block to save weight.
Shane
Old Jun 24, 2008 | 11:28 AM
hellbents10's Avatar
LS1Tech Sponsor
We have programs here for the SBC's and it makes tons of sense when rave weight needs to come down. Also when you don't want weight above the chassis. We build a lot of winning engines that are lightened.
Old Jun 24, 2008 | 06:22 PM
6 & 8 Second Club
How much dough to get a few pounds off??
BBC, SBC, LSX, how much money & how much weight per style??
Old Jun 24, 2008 | 07:14 PM
LS1Tech Sponsor
SBC about $1600 for over 40lbs. Check the website for some pics and info.
Old Jun 25, 2008 | 11:47 PM
6 & 8 Second Club
Thanks for info.
Old Jul 6, 2008 | 10:38 AM
CNC BLOCKS N/E's Avatar
Skroll down this link as ther is some info on block lightning
http://drr.infopop.cc/eve/forums/a/t...2/m/7441071973
