Advanced Engineering Tech For the more hardcore LS1TECH residents
To: GM....Why a 3.622" stroke?
Old Jul 1, 2008 | 12:07 PM
InchUp's Avatar
Default To: GM....Why a 3.622" stroke?
I was bored last night and got to playing around with desktop dyno software and I came across an interesting question. Why do you think GM designed the Gen III/IV LS1 with a 3.898" bore and 3.622" stroke to 5.7 liters, instead of sticking with the tried and true small block design of a 4.000" bore and 3.480" stroke to make the same 5.7 liters?
When I set up the two simulated dyno runs I had absolutely every other variable the exact same, except for the bore and stroke but both runs had 5.7L displacement. The two simulations had the exact same torque and horsepower curves from idle to red line, and according to the data tables the actual output was always within 2hp and about 3lb-ft of torque, so practically no difference. In real life you'd never feel a 2hp/3lb-ft increase difference.
Anyone have insight behind this change? I'm not complaining by ANY MEANS, I love these new motors, I'm just curious as to what they thought paving their own path for a new way to get to 5.7 liters would accomplish.
Let the discussion begin!
Old Jul 1, 2008 | 12:14 PM
InchUp's Avatar
Here...Dyno 1 4" bore 3.480" crank
Dyno 2 3.898" bore 3.622" crank
Remember these are not the actual graphs of either motor. All I did was make two identical motors with regards to a different way to make 5.7 liters as seen with Gen I small block 5.7L's and Gen III 5.7L's like the LS1.
Old Jul 1, 2008 | 12:55 PM
ALLBOTTLE's Avatar
LS1TECH Sponsor
Smaller bore motors promote a more complete and efficient burn. The larger the bore becomes the harder it is to pass emissions requirements.
When the ls1 was being designed int the early 90's GM might have been under the impression that Emissions laws where going to get more strict, and when they didn't the motor was revised and slowly has continued to grow with the addition of new and more effective emission control devices.
Old Jul 1, 2008 | 01:01 PM
Alvin's Avatar
smaller bores typically have slightly better thermo efficiencies also.. which goes along with ^
Old Jul 1, 2008 | 01:15 PM
Ryan K's Avatar
Pathological Modifier
As for the oddity of the numbers, our motors were built metric...
99mm bore X 92mm stroke.
Old Jul 1, 2008 | 02:08 PM
cnorton's Avatar
Ryan, I do believe that you've nailed it!
It's a metric motor all the way.
Old Jul 1, 2008 | 09:37 PM
InchUp's Avatar
Yes I'm aware of this. I just got done building a 5.3L into a 5.7L. I told the machine shop, "bore over to 99mm, it's 96mm now." and he just looks at me funny and starts the conversion process. Anyways, desktop dyno runs in standard units, at least mine does because I don't change the units in the settings file so that's what I stated.
Old Jul 1, 2008 | 09:39 PM
InchUp's Avatar
And this makes total sense. Thanks. Care to elaborate on the 'why' part? Why does a smaller bore, say a 99mm bore vs a 101.6mm bore make for a better burn?
Old Jul 1, 2008 | 10:05 PM
Mean Green z28's Avatar
Less area for the flame to propagate in the same amount of time?
Old Jul 1, 2008 | 10:09 PM
Lol, I know how you feel. I work for an engineering company and we sometimes design our parts in metric since we supply our product worldwide. But our machine shop gets pissed off when we do the drawings in Metric 'cos they have to sit there with their little calculator for a couple hours figuring out the dimensions and tolerances (usually down to .0002") ... lol ... so we started giving them metric parts with standard dimensioning with funky numbers like that and they'll go merrily on their way .. lolz
Old Jul 1, 2008 | 11:45 PM
InchUp's Avatar
As long as your parts don't end up like the space shuttle to Mars, we're good. Metric vs standard mix up my ***! It's prolly a cover up like they say in Transformers.
Ooooooo.....Meagan Fox.
Old Jul 2, 2008 | 12:01 AM
BackInBlack02's Avatar
does this mean quicker burn?
higher rpms because it burns quicker?
Old Jul 8, 2008 | 10:55 PM
Yeah, that was a big ooops!
Old Jul 8, 2008 | 11:22 PM
zjt's Avatar
zjt
fwiw look at the LT5 bore and stroke, 99mm bore and 93mm stroke
Old Jul 14, 2008 | 10:14 PM
MAC4264's Avatar
The 3.62 stroke at 6500 rpm and below in racing type applications does wonders. Most people in the 70's,80's,90's took 400 sbc cranks and put them in 350 blocks to make 383 (4.030x3.75). This type motor would result in a large increase in torque but not near as large for upper horsepower. The old 350 combo would make nice power upstairs but didn't have the torque. Split the 3.75 to 3.48 and you get 3.62 hmm. Maybe the best of both worlds. Born was the LS1 head that could flow on a small bore 3.898. Coupled with the 3.62 stroke to make 346 ci typcial sbc displacement. After that use your imagination LT1 vs LS1. I will say it again 402 (4.200 x 3.62) is going to be the best after market combo ever when people open there eyes.
Just my opinion.
Old Jul 18, 2008 | 11:39 AM
InchUp's Avatar
Wow I never really looked at it this way. What an eye opener to the design process of GM before the LS1 ever came out. Way to go GM!
Old Jul 18, 2008 | 01:50 PM
LS1Formulation's Avatar
Regarding flame front burn theory, think of it this way: Pour two lines of equal amounts of gas out on the ground. One 3 feet long, one 6 feet long. Light them at the same time and you'll find that the flame hits the end of the 3 foot path quicker than the 6 foot path. Gasoline does not "explode" in the cylinder, it actually has a measurable burn time. Since an engine has a limited amount of time to burn the fuel, it becomes more efficient if the flame does not have to travel as far a distance.
Old Jul 18, 2008 | 04:32 PM
DanO's Avatar
My vote is big bore with 2 spark plugs!!
Old Jul 18, 2008 | 10:27 PM
InchUp's Avatar
Look to Nissan 4 cylinders. I just read up on a 4 cylinder Z24i Nissan truck that had 8 spark plugs to pass emissions tests. My friend is looking to turbocharge the little thing so I figured I'd do some side research.
Old Jul 19, 2008 | 03:34 PM
blackz93's Avatar
You had a block bored ~.120"?!
