Wiper arm removal..
Old Jan 14, 2002 | 05:07 PM
Silent but Violent's Avatar
Default Wiper arm removal..
How in the heck do these come off? Got the nut off and tried to put a puller under it but no luck there. Any help will be app. <img src="gr_stretch.gif" border="0">
Old Jan 15, 2002 | 11:04 AM
rom3's Avatar
Default Re: Wiper arm removal..
This is a PITA. You'll probably need a "puller" to get it off. Looks like a gear puller only smaller.
Old Jan 15, 2002 | 03:24 PM
Yeah, got a smaller (but still too big) 2-jaw puller today but it didn't work. I'll see if
Pep Boy's has anything. If I can't pull it off, I'll cut it off <img src="gr_grin.gif" border="0">
Old Jan 15, 2002 | 06:54 PM
The BeaSSt's Avatar
Snap On makes one, kinda pricey but it works.
Dave
ARE/FASTECH 432
www.thebeasst.com
Old Jan 15, 2002 | 07:23 PM
Jackyl_30's Avatar
Yes, you will need a small gear puller to get them off. Don't even try to pry them. They are pressed onto a small conical spline and as you can see they are on tight. I took mine off once and I too had to use a small gear puller.
[ January 15, 2002: Message edited by: Jackyl_30 ]</p>
Old Jan 15, 2002 | 07:52 PM
Thanks, no luck at the Pep. Still searching.... Don't know how to catch up with a snap-on man...
Old Jan 16, 2002 | 09:10 AM
12secSS's Avatar
Oh come on now, you don't need a puller, I used my bare hands. What you do is turn on the ignition, then the wipers until they are vertical, then shut off the ignition. Remove the nut and wiggle (while pulling up) the arm out. It takes a little time but it does come off. Also, be sure not to over torque the nut. You only need ~20 ft/lbs. I over torqued mine <img src="gr_images/icons/mad.gif" border="0"> and busted the transmission mount, now I have to replace it <img src="images/icons/rolleyes.gif" border="0"> (luckily it was an inexpesive part <img src="gr_images/icons/wink.gif" border="0"> ).
[ January 16, 2002: Message edited by: MRZ28HO ]</p>
Old Jan 16, 2002 | 07:12 PM
JohnR's Avatar
Michael,
Here's the deal! I bought a small 2-arm puller made by OTC #1020 ($29.00) at my local "Transmission & Bearing" supplier. It worked very well. The driver's side broke loose with a hard Crack, then it fought me to the very end. The passenger side broke loose fairly easy. I really don't think that the driver's side would ever have come off safely without using the puller; IMO. Now I can get on with the coil relocation project.
Old Jan 16, 2002 | 08:14 PM
MRZ- I'm at the point that I'll give anything a try now <img src="gr_images/icons/wink.gif" border="0"> Thanks
John- Thanks for the info. I knew they had to be a puller out there (cheap). Now maybe I can get on with my coil relocation <img src="gr_images/icons/wink.gif" border="0"> Thanks bro!
Old Jan 17, 2002 | 12:32 AM
JohnR's Avatar
Michael,
I just removed the large plastic wiper covering. Here are some tid-bits that might help you with yours.
Remove the long soft rubber gasket first. You can do this by slipping your fingers under the gasket and around the little pins then gently lift and rock the pin side-to-side simultaneously and they will come right out.
I struggled a little with the removal of the large plastic fasteners until I realized that the little center piece is an expander plug. Use a flat blade screwdriver to remove the center plug first. Then use the screwdriver again to remove the actual fastener.
The next challenge was getting the washer hose disconnected. (what a whimp!) I ended up using the heat from my drop light to warm up the T-fitting. Then it finally separated.
I love this stuff!!!
Have fun,
John
Old Jan 17, 2002 | 06:29 PM
[quote]Originally posted by JohnR:
<strong>Michael,
Have fun,
John</strong><hr></blockquote>
Thanks for the tips! I removed my hood to make things a little easier <img src="gr_images/icons/wink.gif" border="0"> Finally got the arms off <img src="graemlins/fluffy.gif" border="0" alt="[Fluffy]" />
I'm not sure I want to use a sheet metal screw to attach the coil packs to the "cowl". Looks weak for putting and pulling plug wires. Going to try to find a bolt tomorrow to get everything in there snug. Thanks again!
Old Jan 17, 2002 | 11:42 PM
JohnR's Avatar
I'm sitting here trying to devise a simple quick release bracket so I can easily remove the coil packs. I don't like the sheet metal screw method either.
Please keep me informed of your progress.
Old Jan 18, 2002 | 04:51 PM
Ok, here's what I done. I got 2 bolts (2" long and 1/4" dia., I think), droped them in from the top with a washer. Then put a washer on and a nut, tighten it down ot the "cowl". Now, get the coil packs and slip them up on the bolts and put a washer and nut and snug them down with a wrench. Yes its a little tight in there but you can do it. (easier than getting the arm's off let me tell you) And, if ever needed to take them off for some reason, you wouldn't be able to see the bolts hanging down. Woolaa! If you come up with something better let me know <img src="gr_images/icons/wink.gif" border="0"> Looks tough!
