Write-Up: Non-Projector HIDs for Firebird/Trans Am
#42
Bam..they got shipper..actuator was to f'd to get fixed anymore. 2 gears and jb weld killed it lol..got a brand new ac delco for 150 so can't complain - waiting parts then I will take pictures HID + FMIC dumdumdum
#43
sorry for not responding raptor. hope your insatll went ok. my computer has been disconnected. The plug i got was exactly like yours. I just bent the tabs inwards to make it fit the OEM plug. It seemed to seal ok. The HID fogs seem to light the road just as much as the factory halogen headlights, but, at least its a white light and i dont have to flip up the damn "wings".
#44
#46
#49
And i didnt really realize which thread I've been posting in till now. I got confused as to which one was about the HID fog lights an which was about the low beams. Seems like everyone is focusing on this one though. So sorry for talking about the fog lights here!
#57
$70 for the HIDs, shipped. I got the place the OP said to order the sealed beam conversion from to just get me the housings, and those were 68$ shipped. All and all, it came out BADASS and I can finally see the road and absolutely no high beam flashs only thumbs up's because of the FMIC . I will have to get some pictures!
#58
#59
FMIC i believe is Front Mount Intercooler...anyway i know this was a few posts ago but i wanted to try and put my 2 cents in. The easiest way i found to get to the back of the foglights since i dont have skinny arms is...lay down under the car and look up where the fogs should be...there is a smooth cover with i believe three indentions in the cover that have black plastic button clips things. Now if you pull on the raised center with pliers or use a flat head screw driver they will pop out. I actually found it easiest to use wire cutters and squeeze just enought to get under the lip of the center plastic piece. Then give it a tug and the center will pop out a half inch but not all the way out. After you remove the clips they can be reused and put back in. Anyway once these are removed you can very easily pull down the flap to reach the fog lights. Once done just push the button clips back in. Hopes this helps someone and sorry not very good at explaining things.
