Last edit by: IB Advertising
See related guides and technical advice from our community experts:
- Camaro and Firebird How to Sequence Tail Lights<br>Step by step instructions for do-it-yourself repairs.
HOW TO: Sequential Tail Lights
#221
Check out the video in post #96. It shows the new kit. It's a little hard to see on the video due to the reflection of the reflective elements in the housings and the angle of the camera, but you can't tell any difference in luminous intensity between the bulbs. (If you watch closely for the bright spots in the video, this is a little easier to see.)
That's what I was wondering, if it's the camera causing the issue or it is indeed like that in person. I'm definitely putting sequential lights on this car, just debating on which module to buy.
Thanks for the help!
#222
Save the manuals!
![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
There's also an optical illusion going on. Since the inner bulbs are on longer in the sequence, (Bulb #1 is on for 3 beats, bulb #2 is on for 2 beats, and that outer bulb is on for just 1.) your brain perceives the outer bulb flashing faster. If you watch the video closely, you'll see that they they do flash evenly.
#224
Save the manuals!
The outer cell of the lens is just different than the two inner ones. The reflection is totally different and that is what catches your eye. (not so much the luminosity of the bulbs) It looks to me that the inner cells are meant to send the light out linearly from the car and the outer cell is meant more to scatter the light in all directions.
So, it's just all-around diff'ernt. So, I think that's the part that one should be comfortable with. If the car were designed with sequential from the start, I'm sure the lens would be designed more uniformly. (But we'd probably need a different lighting design on the car to meet the regulations for parking light illumination.)
#226
I had posted in this topic several years ago when I got the WebElectric Kit. It worked great for a while, but I fried one of the sequencers by trying it with LED's (There was no warning about it back then) and now that it's broken, my only options are to buy another $90 kit to replace the sequencer, or what I'd prefer to do is upgrade to sequential LED's. I've read through the thread and it seems that no one has a solution for this yet. Any ideas?
If i understand it correctly, the 4th gen T/A has 3 bulbs, the inner and middle being dual filament types and the outer being a 194 bulb (or 921 if you already have the kit). Turning on your headlights causes the dim filament middle and inner bulbs to light. the bright filaments and outer bulbs (with the kit) start sequencing when you have the turn signals on, and come on in sequence and stay on when you hit the brakes, meaning constant power causes them to stay on and on/off/on/off power causes them to sequence. Again, if i understand it correctly, this would mean that the dim filaments are irrelevant in your turn signal usage, and the brighter filaments and outer bulbs would essentially only consist of 3 sets of 2 wires (power/ground) to 3 bulbs. This doesn't seem like a complicated setup requiring a unique sequencer, shouldn't the led sequencer meant for say, a challenger or a mustang be able to be adapted fairly easily for our cars?
#227
Finally got around to ordering my sequentials and promptly installed. 6 months ago I ended up modifying my tail lights the 194 socket to a 3157 and while I was doing that I also swapped out all my LEDs. I just felt like it was worth the effort to put 3157 bulb and also because the actual Trans Am based kit doesn't work with LEDs. LEDs are WAY better than the incandescent lights, my tails are nice SOLID red color which looks so much better (and obviously brighter too). Since I was already running LEDs, I had to order the universal 3 bulb kit (STS-1), which was cheaper ($69). I soldered and heat shrinked all my connections and then loomed wiring from the module. They say to mount the modules actually inside the car even tho it's sealed, but it's just not very feasible to do with our cars. I put my modules underneath the center bulge so they were out of the way of anything and somewhat protected from the elements. Since I had to mount them sideways, even though they're pretty waterproof I put some black RTV inside the end to play it safe. I did have to extend the wire to the furthest light.
I don't think I saw anyone mention trying to use an electronic adjustable flasher. I found a cheap one on eBay and ordered it when I did the sequentials. Super fast shipping and I tested it out on my power supply with a single 194 LED to make sure it would work. It's definitely a blessing to be able to adjust the flash rate to get it to look just right. While it probably would be perfect to people using incadecent bulbs, it doesn't slow it down slow enough for my tastes so I'll order different type and test it out. I can use this one for my hazards.
FYI I did try the EL12 and another electronic flasher i had laying around, but neither worked with LEDs and sequentials.
I did run the wire to the front of the car so my brake lights operate normally. Event ho it sequences fash enough, I just don't particularly care for the sequential brake lights, it just seems like a reason for a cop to pull me over and I like to look as stock as possible. I originally thought you hook it up to your brake light wire pedal, but when reading the instructions you have to hook it up to the right and left signals. I did some testing under there, but never found the signal wires. Anyone happen to know which wires I need to tap into?
![Name: 20160929_170228.jpg
Size: 215.5 KB](https://ls1tech.com/forums/attachments/appearance-detailing/596947d1501261733-how-sequential-tail-lights-20160929_170228.jpg)
![Name: s-l1600.jpg
Size: 33.7 KB](https://ls1tech.com/forums/attachments/appearance-detailing/596948d1501261733-how-sequential-tail-lights-s-l1600.jpg)
![Name: 20160929_175302.jpg
Size: 172.8 KB](https://ls1tech.com/forums/attachments/appearance-detailing/596949d1501261733-how-sequential-tail-lights-20160929_175302.jpg)
![Name: 20160929_175307.jpg
Size: 155.2 KB](https://ls1tech.com/forums/attachments/appearance-detailing/596950d1501261733-how-sequential-tail-lights-20160929_175307.jpg)
![Name: 20160929_182126.jpg
Size: 174.9 KB](https://ls1tech.com/forums/attachments/appearance-detailing/596951d1501261733-how-sequential-tail-lights-20160929_182126.jpg)
![Name: 20160929_195957.jpg
Size: 163.5 KB](https://ls1tech.com/forums/attachments/appearance-detailing/596952d1501261733-how-sequential-tail-lights-20160929_195957.jpg)
![Name: 20160929_1959580.jpg
Size: 171.1 KB](https://ls1tech.com/forums/attachments/appearance-detailing/596953d1501261733-how-sequential-tail-lights-20160929_1959580.jpg)
![Name: 20160929_195959.jpg
Size: 171.3 KB](https://ls1tech.com/forums/attachments/appearance-detailing/596954d1501261733-how-sequential-tail-lights-20160929_195959.jpg)
![Name: 20160929_231710.jpg
Size: 115.8 KB](https://ls1tech.com/forums/attachments/appearance-detailing/596955d1501261733-how-sequential-tail-lights-20160929_231710.jpg)
Quick video to show flash rate
![Name: s-l1600.jpg
#228
Save the manuals!
#229
Thanks for point me in the right direction. I probably should have read thru the thread again since it's been 6 months since I originally read it, lol. I'll have to yank it out and open it up and measure and see what the resistance of the existing pot is now. I'm not totally sure which way the resistance values go to slow it down or speed it up, but wonder if I can just reuse that pot and add a resistor in series with it to slow it down more?
Driving a TA is reason enough, but don't like to give them extra reasons, lol. I just like normal brake lights on my car. The busa on the other hand has different flashing patterns, mainly for safety.
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
#230
Save the manuals!
#231
I need to dig around and find what color the signal wires are under the dash so I can get brake lights to operate normal again.
#232
Save the manuals!
If I recall correctly, the brake signal needs to go through the turn signal switch - so the brake left and brake lights will go out when the turn signal for that side is on. (The filament for the brake and turn signal are shared, so in order to get a flash: the brake light/signal has to go off for whatever is flashing.)
#234
Figured I'd update my experience with some adjustable flashers. The orange one worked decent, definitely better than EL12. Watching my video again kind of makes it look faster than what it is in person, not sure or if the camera didn't pick it up correctly. I got flasher #2 which is was also plug and play. I don't have video, but it slowed it down a little more than the orange so left it for my flasher and used the orange for my hazards.
I haven't tried flasher #3 yet, next time I'm under the dash I'll give it shot and think it may do the best of the 3. Only down side to it is you'll have to ground one terminal of it and I believe the factory flasher plug will easily plug onto the other 2 prongs with no issue.
Definitely recommend getting an adjustable flasher, they're actually legit.
#1: http://www.ebay.com/itm/282124254337
#2: http://www.ebay.com/itm/191982213277
#3: http://www.ebay.com/itm/182236411743
Pictures are in order.
![Name: Flasher%201.jpg
Size: 49.3 KB](https://ls1tech.com/forums/attachments/appearance-detailing/595104d1501256506-how-sequential-tail-lights-flasher-201.jpg)
![](http://img.photobucket.com/albums/v375/InfiniteReality/WS6/LED-SequentialSignals/Flasher%202.jpg)
![Name: Flasher%203.jpg
Size: 35.7 KB](https://ls1tech.com/forums/attachments/appearance-detailing/595105d1501256506-how-sequential-tail-lights-flasher-203.jpg)
#235
Here's my "poor man's" sequential tails. The theory behind this is that LEDs ignite faster than incandescents so it should give a sequential effect. The thing I wasn't sure about was how much faster the LEDs would be and if the effect would be convincing. It turned out not too bad.
I'm using Sylvania ZEVO 3157 Red LEDs in the innermost sockets, with standard white bulbs in the outer 3157 and 194 sockets. I tied the 194 sockets into the signal circuit. I'm also using EL12 flashers.
#237
https://youtu.be/oMO_y7ejhNY
#239
regular bulbs, no leds, this kit was made a long time ago and no longer made, still works good
https://youtu.be/SIbEunZU0kI
