An update on the Edelbrock coil covers.
They don't look very big in that other pic from Edlebrock b/c they have a big single plane intake on there taking away from the focus on coil cover size.
I don't see this as much different than the OE covers on the Corvette, or any other manufacturer's ways of covering the engine to 'hide' crap.
Of course the plastic won't 'hold' the heat like the aluminum would tho, ...
I'm no coil pack expert & I figure they designed them to withstand some heat of coarse, but the question is are they designed to withstand elevated temps higher than normal after the car is shut off & sitting there heat soaking more than normal due to large cast aluminum covers over the packs.
I was under the impression that if things get that hot in there, the coil pacs are the least of your worries.
BTW I did run into the same issue with the fuel line. Same thing with the dip stick on the other side.
I was simply stating the GM & a lot of manufacturers cover the engine area with miscellaneous covers. So I don't think heat should be an issue.
Although, ..., (& here's where the contradiction comes in?), since these are aluminum where-as the factory ones are generally plastic, these may retain more heat than the others?
Simply a statement/question.
As for grinding off the logo, I might, I haven't gotten that far in the thought process yet. If I do, I'll grind off the FAST logo on my intake as well. It's the reason I bought the as-cast versions, because I didn't want to be grind on a polished set or powder coated set.
I have no concerns about grinding them either. It's aluminum and should come off pretty easily.
Brien knows what hes doin....im sure if there was an issue with heat he would have thought of that before purchasing these.
Here's some more pics for those inquiring about how they work and what they look like....
As you can see here, the surface is pretty rough, so grinding these down isn't a concern to me, it'll come off pretty quickly with a grinder. If you look at the setup, the coils are spaced out just like stock, which brings up another thought. What about all the people who place them right next to each other under the cowl? They never report any heat issues. Coils naturally get hot from charging and discharging.
LET THE HEAT CONCERN GO.
Onto the pics...
Here's the backside...
It may be a while before I get any time on this, but I will keep everyone up to speed.
So I worked on removing the logo from both sides. A grinder, then some 100 grit is as far as I've gotten. I'm not sure I'm going to go too crazy since I'm going to paint these, and a few coats of paint and a little bit of sanding in between coats will get rid of the as-cast look.
Here's the first pass on the driver's side with a grinder.
Here's the passenger side after the grinder and 100 grit on a palm sander.
And another angle of the passenger side...
Unfortunately, I'm not too motivated when it's freezing outside and I've got to juggle cars around to get to the t/a. I'm putting together a shopping list to pick up NASTY fuel rails which are polished billet. I'm going to go all black for the AN fittings and it should look good.
