Trans Am Bezel in Camaro
Hello everyone!
Yeah, I know this is a beaten topic, but I recently bought a T/A gauge bezel for my SS. They just look so much better than the flat, boring Camaro gauges. Anyhow, like most F-body applications, it was frustrating getting to the screws and the tabs, but overall it took about 40 minutes to get it in. I had to remove the outer shell (2 screws), then take the whole gauge out (4 screws). The plastic bezel is held to the gauges by 6 arrow-style tabs. Simply pop them out. Now for the part that made me feel like an idiot. I put the new bezel on, and tried in vain to put the gauge set back in.....to no avail! Finally the smart part of my brain started working and I separated the bezel from the gauges; put the gauge itself back in, and then put the new bezel in after. Other than that, a pretty easy install. It looks so much better. Take care. Frank
Edit: that little blemish on the lower left is a wacky reflection and the "check gauges" light came on after it was running for a while and hit the low fuel point. Also, it may look like there isn't any plastic covering the bezel in the first picture, but it's there; just really clear!
As it came from WS6 store (bezel plus new plastic fascia):
Before:
After:
Before:
After:
Hmmm.....my 95 LT1 T/A did the same thing. It used to come on with low fuel as well.
Here is what mine looks like for any of those guys that have white faced. I shot it this morning before starting the car with my cell phone so don't give me any grief please. Cookba, what is your MOS?
Mine are reverse lighted at night and can be set as either blue or green (mine stays blue) and comes with it's own dimmer switch and toggle switch on a separate box. I have it wired directly to my dimmer switch on the headlight ****. I then stuffed it all behind vent ducting to keep it out of sight and mind.
