FAST 92 Painted
Used Adhesive Promoter, Primer, Paint, and Clear.
Finished off by doing the FAST, box and lettering in white. I've seen this paint combo quite a bit on here so I know it's nothing ground breaking, just felt like sharing.
It's NOT sanded by the way, I like the textured look, so I just did some gentle wet sanding w/ 1500 to get the Adhesive Promoter and Primer to properly spray on, then did the paint/clear coats.
After base coats
Cleared
Accented and cleared again
I just cleaned it with Dawn and sprayed it with Krylon Fusion though...worked great. I want to go back and do the logo in silver since everything under my hood is black or silver
Looks nice though
From what I've read though, the FAST isn't a solution to quieting down any noises, and mine already sounds like a shop full of sewing machines, so we'll see. I did get new springs and Yella Terra's as well so maybe things will hush a bit. I have heard quite a bit of this "whooshing" noise ordeal on the newer 92mm's, so we'll see if I fall victim as well.
Thanks for the nice comments BTW
ThunderStruck - If you do ever get around to doing the lettering in silver, post up or pm me the pics. I was torn on white or silver, but decided on white due to the availability of it. I would like to see some silver though.
And my intake made the car noises sound a ton louder. I actually thought something was wrong with my car after the install. The diesel like sounds are louder and I can hear a gargling like sound from the valves closing in the heads.
