!wire mod link?
Old Oct 26, 2003 | 07:08 AM
PacerX's Avatar
Default !wire mod link?
Is there a step-by-step write up of that mod with pictures and stuff?
Old Oct 26, 2003 | 10:34 AM
Poltergeist's Avatar
Here you go.
http://www.poltergeist.us/Misc/Wiremod
Old Oct 26, 2003 | 10:50 AM
PacerX's Avatar
Thanks!
One question...
I heard there was another way to do it without cutting the wires, is that true?
Old Oct 26, 2003 | 11:51 AM
Steve1969LS1's Avatar
Yes, its true..
Way #2 - involves making holes large enough to pass the connectors through. Look at the connectors and you will get an idea of how large the hole needs to be.
Way #3 - well you have to know what your doing but you can take apart the connector and re-assemble them on the on the other side of the hole. I do believe this involves a special tool.
Personally, while I know the "cut the wire method" seems scary its really not that bad if you take your time and have a plan. And the smaller hole is much better looking (imo). Whatever way you decidet the basic idea on that link is the same.
Good luck,
wire mod patient 0
Old Oct 26, 2003 | 04:37 PM
PacerX's Avatar
Originally Posted by Steve2000SS
Yes, its true..
Good luck,
wire mod patient 0
I think I'm going with way #3, all you need is a heavy sewing needle to get the terminals out of the connectors.
The only question then is wheter or not the wires are long enough. Are they?
Old Oct 27, 2003 | 03:11 AM
Diesel's Avatar
The wires should be long enough if you keep the hole for them to go through the fender as close to the strut support as possible. I just did the mod w/o cutting and it was a pretty straight forward, however, I had to stretch my wires as I made the hole a little too close to the fender portion of the engine compartment.
Old Oct 27, 2003 | 05:02 PM
slow's Avatar
you just need a sewing needle, i have 2 of the special tools if somebody needs to borrow them, (just pay shipping both ways)
here is all you need to copy though, a needle will work fine.
http://www.fuelslut.com/mem_pics/wiremodtool.jpg
hope that helps
Ryan.
Old Oct 28, 2003 | 06:18 AM
SSDriver's Avatar
anyone have a link for option number 2 or 3. Thanks
Old Oct 30, 2003 | 06:24 AM
travisnd's Avatar
to the top!
Old Oct 30, 2003 | 12:12 PM
MIGHTYMOUSE's Avatar
this is my car and the 'no cut wire' method.
also did a few twists of my own... hid all 4 grounds from the engine bay while i was at it.. and did the same thing on the passenger side.
http://community.webshots.com/album/64999662fXYdvY
Old Oct 31, 2003 | 10:42 AM
Silver02W's Avatar
Default vaccum line?
well i decided to give this mod a shot and its going fairly well. but i have a question about the vaccum line . i did the "no-cut" method but how did you guys who also didnt cut run the vaccum line? can i just pull it from the "T" its connected to up by the pcm . then run it under from front to back then out my new hole then plug it back in. if so will it do anything if i unplug it ? or cant you do this .just dont want to yank it off and then find out that was a mistake.. thanks
Old Nov 3, 2003 | 08:20 AM
Silver02W's Avatar
cant figure out how to pull apart vaccum line , any tips . dont want to mess it up and be pissed i didnt take the time to ask. i tried just pulling the 90* rubber boot off the t but it wasnt having it . am i going about this wrong or do i need to pull harder . i just dont see how the hell you would get it back on if its that tight coming off?
Old Nov 3, 2003 | 08:32 AM
its just never been off before.. it will break loose, try twisting it.. or break it loose with a small screwdriver
