Paging Steve2000SS!!!!!!!!!!
Steve
My Car
I was digging throught some stuf that I had gotten, and found the business card of the co. that sells the bow tie bolts.
It is:
Hilco Fastener Warehouse.
# 714-534-6882
e-mail hillco@hillcofasteners.com
If I recall correctly they only sell standard size bolts so you would have to tap out any locations where you would want to put them
Andy
Steve???
Anyone <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
Steve
I think I used the #20 bolts.. I will go down and check what Tap i used to modify the bold holes from the 10mm. Its actually pretty close to 10mm so the tapping is not that hard.. just take your time using proper tapping techniques <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Yes, Hillco is where I go.. in fact i was there yeasterday.. Funny thing is the Hillco guy said a Camaro guy said he saw my car at Super Chevy and was in there buying up bolts and washers.. so much for me being unique.. lol
steve
<strong>Steve, can you tell me the exact size of the bolts? I don't understand all the numbers and stuff. What is the metric size? Any help would be great!!!!! I'm not trying to steal your ideal since I'm about 2000 miles away. I'm sure we'll never see each other. Its just your car is an imperation to all of us!!! <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> Thanks alot!!
steve</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Actually I am trying to go to Bowling Green.. so I will tell you in October.. LOL.. Just kidding.. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
I will see what I can find..
Steve
Standard Polished bolts
Metric polished bolts
Colored accent washers
I use a 1/4 20 NC (non corse) tap to convert the 10mm factory bolt holes so that they will accept the standard bolts. When you tap have patience.. start it carefully and go a bit then back out.. then go a bit.. a little oil will make your tap last a LOT longer.. dont be afraid to use pressure.. its a feel sort of thing.. I did it and im by far no expert <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" /> -- Oh, I only did this to my bolts in the radiator support.. the bolts holding the fenders on are dome-headed 10mm metric bolts (stainless steel)
My most common washer size is 3/8 ~ I use this with a 1/4 20 7/8 chrome bowtie bolt with integrated washer (washer fits in aluminum washer so it must be 3/8).. They dont use part numbers so its sorta hard.. I use 1/4 colored washer and 1/4 chrome washer (with stainless 10mm bolt) for miscelanious grounding bolts and such..
Your best bet is to find a fastener store in your area.. they typically cater to the "hot rod" guys and older cars.. This way you can do what I do and take bolts in and ask for something nicer.. or try different sizes and such..
I hope this helps a litte <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
