My Interior and Engine Bay.......Build Thread
Old May 18, 2009 | 06:27 PM
PUNISHER TA's Avatar
Cool My Interior and Engine Bay.......Build Thread
Well I havent really been posting in the Appearance section much, but i read through all your threads looking for inspiration.
I have a build thread in the Gen IV Internal Section, but ill leave that for my engine work. Which will be a LSX 454/PRC 265 Heads/LS7 Intake..blah blah..(Well...Its all in my sig.)
INTERIOR
I started 5 months ago, tore my car apart and welded in a 10pt cage.
Then i put down a layer(or more in some places) of Raamat
I guess I dont have any pics of the ensolite, but i put that on also. and right now im procrastinating, working on the carpet. Cutting the holes and such.
ENGINE BAY
Yesterday i had a friend come over and help me drop the engine.
Today i pulled the wiring harnesses and began drilling the spot welds out. I also started fabing a cover to weld over the hole where the A/C used to be.
PLANS
I will be relocating the computer inside. The battery will go to the back.
The fuses will be dropped under where they currently sit(somehow).
I will be deleting ABS (along with basically everything else i can) and adding LL and a PV, these will be mounted on the frame rail somewhere.
New lines will be custom bent so there out of the way.
Also i will run braided fuel lines
Both the fuel and brake lines will be moved away from the exhaust when i re-run them
I also am looking for a way to "Wire mod" the big group of wires to the fuse box
If you have any ideas or suggestions let me know. (Positive or Negative) I can handle it
Old May 18, 2009 | 07:03 PM
98 WS6's Avatar
Damn dude.. Gonna be a big project. I wish I had somewhere to do all that work. How was it getting everything in the interior out? How long did that take?
Good luck man, keep us posted!
Old May 18, 2009 | 07:11 PM
HotWhipT/A's Avatar
I did the !wire mod to the front of mine like I think you are talking about. The big bunch that goes to the fuse boxes. You know how you see it right there under the air lid? I ran that bunch behind the frame under that black plastic shield and between the radiator. Theirs just enough room and works just fine! I have not burnt anything either.
Looks good man!
Old May 18, 2009 | 11:07 PM
Thanks.
Yea, im really not good at taking things slow, or doing something half ***.
Looks good man!
Yea. well i have everything out right now, so its hard to picture. But yea. that sound like a good idea.
I also wanna do the wires, that go to the fuse box from the firewall somehow.
btw, your engine bay turns out very clean. I would like mine to be emptier... lol well see how it turned out
Old May 18, 2009 | 11:17 PM
Well I got my A/C Delete Panel welded in part way.
Also I cut out the panel under where the Fuse Panel sits. Ill be welding in a falt panel. and obviously smoothing that out.
Old May 19, 2009 | 12:08 AM
TORCHD 02 TA's Avatar
Brian i had all my seats and center console out of my car in less than 25 mins.. it is easy. i was to put down some E-dead..
OP looks great. lot of work. i think you may want to change out the Borla.. Going to be raspy...... But that is JMO
Good Luck
Old May 19, 2009 | 01:27 AM
Good Luck
Yea is was easy,
Seats first. then i slowly popped off the side panels.
The dash you really just gotta take your time. I thought i was done. and then i found 4 more bolts.
Thanks.
Yea. I saw in another thread you mentioned the borla with headers/y was raspy.
I havent bought it yet. That just what i was planning. I will have 2" Kooks. but i heard someone else say to just put a spiralflow after the Y
Old May 19, 2009 | 03:26 AM
dragonZ28's Avatar
Prop the front suspension up. I did it the same way, and tore a brake line. All that weight is pulling on them.
Old May 19, 2009 | 03:38 AM
Nimitz87's Avatar
subscribing...looks to be an amazing project!
Chad
Old May 19, 2009 | 09:39 AM
raptorws6's Avatar
Looking good.
Old May 19, 2009 | 10:25 AM
White.Lightning's Avatar
I'm relocating my PCM inside as well when I do a A/C delete. Subscribing for ideas on the fuse blocks on the driver side. Nice work!
Old May 19, 2009 | 12:53 PM
Default Mega Reply
I wasn't really worried about them, cause ill be getting SS lines. But i guess i might as well have them as back up, Ill support um. Thanks
BTW. Ill be ordering some SS Badges from you before this is done.
Chad
Thanks, Its a bigger project than i EVER planned. lol
I keep getting more and more ideas.
Originally Posted by raptorws6
Looking good.
Thanks
I think its gonna really clean up the engine bay.
Thanks
Old May 19, 2009 | 02:05 PM
Im wondering why nobody smooths the line where the two pieces are spot welded together. Some people smooth the spot welds but not the "line"
EDIT:
NOTE: Ive never done body work, so this is all new to me. I am learning as i go. As usual.
Old May 19, 2009 | 02:29 PM
You can weld/grind it, then use body filler. If you just use body filler it might end up cracking on you if that area is prone to any flex.
I welded all those holes shut from the wire mod and TCS delete; followed it with some bondo and some paint. Looks nice.
Old May 19, 2009 | 02:40 PM
Yea, i already have the holes welded shut. I was think of "stitch welding" as youre talking about. but i just wondered why no one has done it yet.
Old May 19, 2009 | 02:47 PM
Do it up. When I pull the motor for a new one I will be doing it. It's just a lot of work. Most people could give two ***** less about small details like that but that is what makes certain engine bays "pop". When I see a CLEAN engine bay, I admire the time and attention to detail put into it.
Old May 19, 2009 | 03:59 PM
Yea. I guess ill just be pissed if for whatever reason I mess it up. But I guess im gonna start that. get all the welding done today.
Still need to finish my interior... lol
Trimming the carpet isnt gonna be fun.
Old May 19, 2009 | 05:00 PM
You kinda can't mess it up. It's just metal! Haha. You can always cut/grind/weld to get it right. Take your time and you'll be fine.
Old May 19, 2009 | 08:12 PM
Well, Ive got it half done. Ill post up pics tonight.
Old May 19, 2009 | 11:26 PM
Tonight's progress
