Has anyone tried this??
i just posted my install of the adapter/****. i haven't tried cutting down the stick though. but the plastic actuator seems like it goes the entire length of the shaft. but the key is to cut the outside first, then cut the plastic. when you're done you're gonna have to cut small little notches so the stock shiftknob and the staple can slide back in, or so the adapter can screw on and stay if you use that. it should still work, but i'm not positive.
here's the link to a guy that did it.
https://ls1tech.com/forums/appearanc...-write-up.html
