EBAY fog hid kit/conversion WHICH ONE!?
Old Jul 1, 2009 | 03:49 PM
lemons12's Avatar
Originally Posted by VIP1
Wait... you are putting these in a Firebird? You need conversion housings or projectors. There currently isn't an all-in-one setup for the Firebird to replace the stock sealed beam headlights. I and others have installed projectors. Others have used conversion housings. Some conversion housings handle HID ok but not great, others handle it really badly (horrible glare). If you search around on here you'll find plenty of threads. You can also check out the Lighting FAQ.
Firebird
Low Beam: 4703
High Beam: 4701
These are sealed beam units, not small bulbs like on the Camaro or more other modern cars.
Sorry for the confusion, when I saw references to 9005/9006 bulbs, I thought you had a Camaro.... then I noticed your sig.
If you only want to do your fogs, the stock fog light bulb is 880. So the appropriate HID kit would be an 880. Many people have put HID in the stock fog light housings with varying success. Some had melted housings.
I'd like to see some beam pattern pics of HID in the stock T/A fog light housings. I suspect its conical instead of low & wide.
great info!!!! thats what i needed!
im looking to get out cheap so i guess ill just buy a 4703 HID kit (i can use my current stock head light, right?)
OR do i have to go with projectors or an aftermarket housing for trans ams?
6-8k one of the two have not decided yet..
Old Jul 1, 2009 | 04:23 PM
98 WS6's Avatar
Lemoins.. If you want to do fog lights, you will need an 880 HID kit, that's it. It plugs in and replaces your fog light buklb.
If you want HID LOW BEAMS, you will need to take out your factoey Sealed Beam housing (meaning that it's sealed, you cannot just change a bulb, that whole thing practically is your "bulb") then you would need to replace with a Sealed Beam conversion housing. A company called Eurolights sells these, you could also find some on ebay probably. THEN, depending on the kind of conversion housing, (meaning what kind of bulb type it replaces it with) you will need to get an HID kit matching that bulb type. Fore example, if you get an H7 EuroLight sealed beam conversion housing, you will need an H7 HID kit.
Search for my writeup, I think it's called "Firebird Non-Projector HID." It should give you an idea. If you REALLY want awesome lights, then you can ditch the seaked beam housings completely, and replace them with projectors. This takes more fabricating, and I know nothing about it. There are a bunch of things about projectors in the Lighting FAQ, VIP also knows his way around those quite well.
Old Jul 1, 2009 | 05:33 PM
lemons12's Avatar
http://eurolamps.com/eurolamps/camaro_headlights.htm
so i need those...
and all i need is the housing, no lights or anything..
then when those come in, replace my factory ones..
then go buy a hid kit for.... 4703?
im trying to understand!
Old Jul 1, 2009 | 05:52 PM
97ramsst's Avatar
Sup homie! These are the ones I recommend to everyone
http://cgi.ebay.com/ebaymotors/Slim-...1%7C240%3A1318
Digital slim ballasts are very reliable. Their also 100% plug and play. You'd have to buy them, then send him a message in ebay/paypal that you want an 880 kit.
Thats who I bought mine from...ACTUALLY 7 kits in all (all 3 sets for the SOM car, two for the F350 and two sets for my buddies BMW!!!) And they are great.....
so i need those...
No the bulbs for those are H7s. You are replacing the sealed beam 4703s with a housing that will hold a H7 bulb.
Old Jul 1, 2009 | 05:55 PM
lemons12's Avatar
EDIT::: you have aftermarket housings right?
so to get that look i need to buy he housings from euro lights and then the slim ballast set off ebay... and ill be good to go..
Old Jul 1, 2009 | 05:58 PM
97ramsst's Avatar
Right...I have the eurohousings for both high and low beams...but you really only need the lows. Email Peter at eurolights (tell him Robbie Lewis sent you) and he will hook you up!
Old Jul 1, 2009 | 06:03 PM
lemons12's Avatar
awesome...
THANK YOU SOOOO MUCH everyone for all the help!!!
i actually somewhat understand it now..
im going to do the euro housings with the ebay slim kit from vtec or whatever his name is...
then grab an 880 HID kit for the fogs...
thanks again!
i will update thread when i get everything in..
Old Jul 3, 2009 | 03:04 AM
199TAmaster's Avatar
Does anybody else make the housings? I cant find any on Ebay
Old Jul 3, 2009 | 11:36 AM
lemons12's Avatar
i couldnt find any cheaper ones.. or any at all for that matter..
Old Jul 3, 2009 | 12:21 PM
VIP1's Avatar
Copy & Paste Moderator
Bosche and Hella do make conversion housings. They appear to have better output, but also much more expensive.
Check out Rally Lights. They have them. If search around on here, you should find some threads on them too. (Now I forget if those threads where 1993-1997 or 1998-2002, which certainly makes a difference.)
Avoid cheap ebay knock-off, especially the ones where the reflector looks like a daisy or sun burst... they have horrible output. Also avoid the fake sealed beam projectors that are on ebay. They are not projectors, just a crappy sealed beam with a hunk of glass stuck inside and bad output.
Old Jul 3, 2009 | 12:54 PM
VIP1's Avatar
Hmm.... I can find threads and pics of the Eurolamps and Bosche units, but the only decent beam pattern pics I can find of the Bosche are with the standard Halogen bulbs.
This thread has an HID pic:
https://ls1tech.com/forums/appearanc...-you-want.html
Here are some other threads on the Eurolamps and Bosche sealed beam conversion housings:
https://ls1tech.com/forums/appearanc...dlights-t.html
https://ls1tech.com/forums/appearanc...hids-pics.html
https://ls1tech.com/forums/appearanc...-question.html
https://ls1tech.com/forums/appearanc...like-fogs.html
https://ls1tech.com/forums/appearanc...5000k-hid.html
https://ls1tech.com/forums/pontiac-f...-my-ws6-2.html
For the price of some of these setups, you can get projectors.
Check out the Lighting FAQ:
https://ls1tech.com/forums/appearanc...hting-faq.html
For more info on lighting upgrades in general. There are threads in there also on projectors. If you want to go the easy route, you can get Hella 90mm H7 projectors and an OEM D2S HID setup and adapter plates or an H7 HID Kit. Total cost would be under $350 (projectors, HID, hardware, wire...).
I have the Hella 90mm H9 projectors. I got the H9 version instead of the H7 version because H9 is the brightest regular Halogen bulb you can get and I wasn't sure If I wanted HID at the time. I've since then modified them for better output and installed HID. My thread is in the Lighting FAQ. There are better options out there for projectors, but the Hella 90mm projectors (H7 & H9) have decent output and are easy to install.
Old Jul 3, 2009 | 01:12 PM
  #32
Nacho SS's Avatar
DDM Tuning
x eleventy billion
Old Jul 3, 2009 | 03:11 PM
  #33
lemons12's Avatar
thanks for all the info guys..
seems like the eurolights are just barely better than stock.. or more convenient...
i might go with the HELLAS or Bosch..
keep it coming!
Old Jul 3, 2009 | 05:56 PM
  #34
98 WS6's Avatar
Thanks for clearing some of that up for me, Robbie.
VIP, Are the Bosch sealed beam conversion housings any better than the Eurolights? I have a decent amount of glare, but regardless of the housing I would still have glare, seeing as I have HIDs in a reflector housing. I was just wondering if one is any better than the other.
Old Jul 3, 2009 | 05:57 PM
  #35
TheSilverOne's Avatar
Originally Posted by vip1
ddm tuning
Originally Posted by nacho ss
x eleventy billion
+1
Old Jul 3, 2009 | 10:38 PM
  #36
VIP1's Avatar
Regarding Halogen, the Bosche housings have a better defined beam than the Eurolamps. Regarding HID in the Bosche housings, I only saw one pic and the pic wasn't that great so I can't really judge by that. Although the cut-off did seem a little more defined. I need more pics to really decide. I'm not impressed with the HID performance of either the Eurolamps or Bosche, but they are better than the crap knock-offs on ebay There are some on here (ex: InfiniteReality) who have had both sets of housings and said that the Bosche ones were better (I think one of the threads I linked above talks about it).
Old Jul 4, 2009 | 01:10 AM
  #37
Where can I find these Bosche E-code housings? I haven't had any luck. Also would somebody mind posting me a link to some on ebay, just so I can see for myself.
Old Jul 4, 2009 | 12:35 PM
  #38
VIP1's Avatar
I think Rally Lights has some.
Old Sep 1, 2009 | 01:00 AM
  #39
extinctls1's Avatar
How did it turn out??
Old Sep 1, 2009 | 01:06 AM
  #40
lemons12's Avatar
Sold the car I was going to put them on..
The lady is going to get me some Hids for Ann. I believe.. So I need to get on buying some housings.. Whatever I end up doing I will post pics!
