mcguire headlight cleaning
Old Jul 4, 2009 | 08:35 PM
04600rr's Avatar
Default mcguire headlight cleaning
Not sure where to put this or if someone has done this before but thought I would share my results.
Picked up the Mcguire headlight cleaning kit for 20 bucks.
Removed the headlights off my wife's 2000 honda civic.
Wiped the headlights down with a paper towel and then just followed the directions on the box.
I used a skill 1/2 cored drill.
Overall I am pleased with the results.
Attached Thumbnails mcguire headlight cleaning-003.jpg   mcguire headlight cleaning-004.jpg   mcguire headlight cleaning-005.jpg   mcguire headlight cleaning-006.jpg   mcguire headlight cleaning-007.jpg
Old Jul 4, 2009 | 08:49 PM
ULTIMATEORANGESS's Avatar
they look brand new. i just bought new headlights for my SS. cost me $250. they were in pretty bad shape though.
Old Jul 4, 2009 | 08:53 PM
04600rr's Avatar
thanks....this was really easy to do...Only took one coat of polish
Old Jul 4, 2009 | 09:29 PM
black01_WS6's Avatar
ya I have seen really good results with this stuff. I usually use a 1000 grit sand paper and work my way up to 2000 using soap and water, then use a plastic polish and it is a lot cheaper but doesn't look as good, but not too bad either.
Old Jul 5, 2009 | 10:52 AM
Lotus289's Avatar
Yeah I did the same thing to my headlights. Mine were even worse than those, you could actually see the 'scaling' of the plastic from the corrosion. I used the headlight cleaning kit and it worked incredibly well. But there was still a haze over them. So I grabbed a bottle of Meguiers Plastix and it took that haze right out!
Old Jul 5, 2009 | 11:52 AM
04600rr's Avatar
maybe they updated the kit because mine came with the PlastiX.
Old Jul 5, 2009 | 12:39 PM
ILLWS6's Avatar
I just use straight plastix on the wifes wrx. Haze gone.
Old Jul 5, 2009 | 01:13 PM
Lotus289's Avatar
No, the kit I got wasn't from meguiers. It was a 3M kit that just came w/ some rubbing compound. It worked really well, but Plastix made them perfect.
