Dash LEDs super easy, plug play
http://www.superbrightleds.com/cgi-b...ct=CAR#WLED-x5
p# WLED-xHP High Power LED bulb
I love it, BUT the after market overlay doesn't look good. Yes its bright but it looks blury. I don't dive it at night, yet but its a COMPLETELY different story with my OE cluster! Super nice!
This sucks, I have a day time cluster I like and now a night time. Here's a pic of the OE cluster.
I did buy separate LEDs and soldered them into the HVAC plugs. That part isn't that easy.
I see you also have the same type of overlay I got. Do these get rid of the blury look??
Also how do those fit? Do I have to solder them in?? Square peg round hole comes to mind....LEt me know, I'll then put these lights I just got in my LT1 cluster and use the ones you say in the LS1...
Here is what mine look at night its a crappy camera but you get the idea
So this WLED-xHP bulb (1 of them) is plug and play and changes the color of the entire cluster minus the odometer?
I ask because I really like the white clusters on the new Mercedes. I was wondering what it would take to change the cluster/odometer/hvac to white.
From what I understood from Mark that the McNord gauges had no color on the overlay so I'm curious as to if you used white LED's why it's showing up as pink/red?
Also, the pic in my sig is my custom overlay and the pic I showed is my stock cluster with LEDs in red.
As I said in my first post. The stock cluster looks so clear at night, my overlay in white (in sig) has like a blury look to the #s.
I'm going to buy another set, I can put these in LT1 stock cluster and go with the ones with 6 LEDs. I hope to get that clear white look as in the new cars. I want the vette look to my cluster this is why I modded a C5 bezel on to my TA bezel.
Then 2 of the remaining 8 are your turning signal indicators to tell you which way your blinker is on. So you can put any color led you want them to be. I put mine red or amber i think. The last bulb of the 8 is your headlight bright indicator which i changed to blue of course bc thats what its suppose to be. For the turning signal and high beam indicators i used these leds (WLED-xHP).
Now i just changed the 5 black lighting ones at first to (WLED-xHP6) and i could still operate my dimming switch. When i changed the last 3 (turing signal and high beam indicatiors) to these leds (WLED-xHP) i lost my dimming switch. Its not really a big deal tho there are the right brightness for me.
On last thing the leds are from superbright thats where the part #'s are from im using. the x in the number changes to what color you get so for intense if you got cool white the P/N would be WLED-CW HP6, if you got red like me it would be WLED-RHP6 and so one with the different colors. Now i hope i didn't confuse anyone.
Just changing the 5 guage lights to LED.
