Bulb to LED List
Old Jan 23, 2011 | 07:22 PM
  #141
my bandit's Avatar
how do you do the headlight switch for a trans am? i cant find a write up for it
Old Jan 23, 2011 | 07:24 PM
  #142
Ls1CamaroGuy87's Avatar
^^You can replace the bulb...The SMD one is your best bet
http://www.superbrightleds.com/cgi-b.../specs/NEO.htm
Old Jan 23, 2011 | 08:19 PM
  #143
my bandit's Avatar
i thought the trans ams had to be soldered in? and what size? 3,4,5?
Old Jan 23, 2011 | 09:04 PM
  #144
^^No need to solder. Size 3 with the SMD.
Old Jan 23, 2011 | 09:42 PM
  #145
my bandit's Avatar
oh well thank you for that. i just ordered all my guage ones
Old Jan 27, 2011 | 08:21 PM
  #146
Chaotic94's Avatar
Hey guys. Sorry if I'm digging up an old thread. I have a 1994 Camaro and I'm wanting to do the gauge cluster, map lights, dome light, HVAC, and headlight switches all in cool white. Can anyone tell me exactly what I need to do this. I know I need 4410 Festoons for my map lights. Other than that, I'm lost. help is greatly appreciated. Also if anyone has pics of LED's in a 1993-1996 Camaro, I'd love to see how it turned out.
Old Jan 30, 2011 | 02:31 PM
  #147
rasputin's Avatar
Let me start off by saying that Sylvania site is wayyyy off and would recommend doing some searches beyond just using that list. Here is what worked for my 97.
Dome: 4410-CWHP9 Rigid Loop Festoon (the clips have to be bent with needle nose pliers to fit correctly, and the LEDs shine toward the back of the car and not down which is too bad)
Map: 2X 4410-CW9 Festoon (be very careful pulling these out because the base might come loose)
Glove compartment: 194
Rear Markers: 194
Rear License Plate: 194 base (WLED-x5)
In the door (courtesy): 74-W (wouldnt recommend doing these as the space is so small and the angle does not allow for any light)
I would highly recommend doing the MAPs and the Dome. Its probably one of the best mods I have done for the money. All in all with shipping, it was around $25.00.
EDIT, See results below. For some reason the digital camera turn its blue. Its not blue at all, but a pure white light so dont be scared to order pure white like I did.
Old Jan 30, 2011 | 03:07 PM
  #148
offroadfury6's Avatar
out of 6 vehicles, I have found the slyvania site to be pin-point accurate... hmmm?
Old Feb 6, 2011 | 04:12 PM
  #149
The Guz's Avatar
Originally Posted by The Guz
I did one set andI want to say that I either used 470 ohm or 560 ohm 1/4 watt resistors. I dod not ahve a picture at the moment of them on. the only downside is that they are a little dimmer with the rubber cover on them. I forget what brightness I went with but you can get some brighter ones. Also when doing these mae sure the LED is facing straight up so the light points to the writing on the buttons.
Here are some photos I took with my phone just to give you an idea of what the steering wheel lights look like.. I should have used brighter LEDs but these were more of a project.
Old Feb 7, 2011 | 03:32 PM
  #150
MTBSully's Avatar
looks real good man^^^
anybody have pictures of LED brake lights and/or reverse lights? What would i need to do this in my camaro? Thanks
Old Feb 9, 2011 | 09:16 PM
  #151
HoLLo's Avatar
This is really making me want to finish LEDs throughout my car. Particularly the interior and license plate..
Here's my reverse lights
Daytime stock vs led
Old Feb 13, 2011 | 07:41 PM
  #152
rasputin's Avatar
hmmmmmm indeed. they didnt all work for my car, dont know what to tell you????????? therefore i thought it would be helpful to post what actually worked for mine. this way i might help save someone 20$
Old Feb 28, 2011 | 11:04 PM
  #153
camarox302's Avatar
I have a question since Its hard to find a solid answer. I want to replace a few of my lights to LED's. For the map lights / dome lights I love how the stock setup does the dimming. Is there a set of LED's that will have the same effect.
I see the recommended ones from superbright leds on here a bunch, but will they do that?
Old Mar 1, 2011 | 05:19 PM
  #154
94 Camaro Z28's Avatar
Hey guys I need some help. I ordered a full interior set of LED lights and i got the rears (convertible) put in. Now I'm at the map lights in the mirror and i need to figure out what needs to be done to the new bulbs to get them to work?
I have the 4410-CW9 x2 and i read that you need to take the caps off the old bulbs and somehow put them on the new lights? I need to clear up wheather or not you're suppose to slip the old caps over the new or swap them? If anyone has further details, please do share! Thanks
Old Mar 1, 2011 | 08:48 PM
  #155
rob69zombie's Avatar
Just put the lense covers back over them. I just installed mine and they look awesome. Good list; I read about the Festoons, went on superbrightleds.com and ordered them and that was that.
Old Mar 3, 2011 | 09:00 PM
  #156
uLs1a's Avatar
I just ordered LEDs for the dome light, the review mirror, the light in the doors and the shifter indicator. The light in the door locks and window swtiches what LED is that?
Old Mar 3, 2011 | 10:13 PM
  #157
MTBSully's Avatar
Rear Markers: 194
where did you get your LEDs from? PM me if you need to. Thanks
Old Mar 4, 2011 | 08:12 PM
  #158
94T/A5.7LT1's Avatar
im going to be ordering leds for my lights. I went through the pages a couple times to make sure im ordering the right bulbs but I want to triple check. The car is a 94 trans am t-top and I want to replace mirror lights, dome light, and the lights in the door panel for the switches (I know I have to drill the red lense out).
heres the list
-mirrors: 4410-x9 (2)
-dome: RL4410-xHP9 (1)
-doors: T1.5-xHP (2) <--- Not sure if thats the right LED number had a hard time looking for the 74 bulb
Old Mar 23, 2011 | 11:33 AM
  #159
chon79's Avatar
Small thread bump.
I will post pictures tonight, but i switched out my gauge cluster and HVAC with Red LEDs for my TA, and it made a HUGE difference. No longer looks pinkish, especially the HVAC (which was very dim on the left side and the bulb was good)
Old Mar 23, 2011 | 07:57 PM
  #160
Trans-Am Terrorist's Avatar
Rear View Mirror - 2 of 4410x9 Festoon LED Bulbs
Direct replacement for stock bulbs. They are a lot easier than trying to rip the mirror apart to fit boards in there.
These are most definitely NOT the right ones for a 2002 Trans-AM...
I made this mistake and found out the hard way... For models NOT Trans-AM they are the 4410 (as stated above) HOWEVER, for Trans-Ams they are wedge lights (194) NOT FESTOON
Looks like I have to place another order...
So I have two perfectly good 4410 lights (unused) if anyone wants them... Just figured I would save the headache for some other people out there...
