Bulb to LED List
Should come out rather easy. Or use a "bulb puller tool".
I actually only got one mirror LED in, could not get the second one in because I bumped one of the metal holders and could not get it back in place so gave up on it last night. Also couldn't get the door lights out, but read through the thread and found some tricks I'll have to try tonight.
Is this the right one i'd need? Also is this on superbrights website or is this from someone else? Thanks guys!
These are your best option for reverse lights at the moment:
http://cgi.ebay.com/ebaymotors/2pcs-...ht_1810wt_1163
Also, using a led strip will make the lighting more even on the license plate vs. having just one bulb. I used this strip for my license plate:
http://cgi.ebay.com/Flexible-Car-Str...#ht_2901wt_903
There is no way the spider LED is compatible with our reverse lights, it barely fits in the brake light section, which is larger than the reverse section. It is also not the best LED choice for the brake lights for that matter.
Hope this helps.
EDIT: or you can bend the little contact wires on the bulb or socket so it will be more snug. I had to do this to some of my gauge LEDS.
What resistors are u using? Any pics of them installed?
