Bulb to LED List
http://www.virtualvillage.com/white-...02512-078.html
Just a simple look will help... Go out to your car and look at the bulbs... If they are tubes then you will get the festoons. If they are simple little bulbs they are the wedge lights (194)
also what are the stock size/# of bulbs used in a '99 cluster?
And has anyone used LEDs for the tails or third brake light?? Any real difference with them? I've got VHTd tails, so I'm wondering if they'd be brighter.
And I can't get the rear view bulbs to sit right either. I used the 4410x9's. the xHP9's won't work. The 4410x9's FIT, but something isn't making a complete connection. I pulled the rear view off and apart to figure it out. they're a little tighter now, but when I start the car, the vibration of idle loosens something.
And it called for 3 of xHP3 for the HVAC panel. They fit good and work, but I only found a spot for two of them.. Ideas??
Should come out rather easy. Or use a "bulb puller tool".
I have my radio apart and am looking to order LEDs to replace.
http://cgi.ebay.com/ebaymotors/DE317...item2314367ac4
I'll do the 7" led strips eventually.
