Trans Am Console in a Z?
Old Oct 5, 2009 | 12:42 AM
Revson's Avatar
Default Trans Am Console in a Z?
Not sure if this is the right forum for this, but thought I'd give it a try. I just bought a 95 Z with a blown head gasket for a winter project. I used to have a 95 Trans Am and I was wondering if the consoles were interchangeable. I would like to have the t-handle style shifter of the TA and the perf mode switch.
Old Oct 5, 2009 | 12:45 AM
frankmarroquin's Avatar
Basically everything between the f bodies are interchangable.... Pretty sure someone will chime in.
hitmanws6's Avatar
you dont need to change the console to change the shifter ****, they are interchangeable
Old Oct 5, 2009 | 12:56 AM
98 WS6's Avatar
Get a flathead or a pair of needle nose pliers. There should be a pin in the back of the shifter. Pull the pin out, and pull the shifter off. (just the handle will come off obviously)
Old Oct 5, 2009 | 06:07 PM
VIP1's Avatar
Copy & Paste Moderator
The handle is easy to change. There is a staple in the front facing the radio. Pull out the staple, and pull the handle up.
The performance switch is a different matter. That is a function of the transmission. You can't just wire up a switch unless the trans also has that feature.
Old Oct 6, 2009 | 01:34 AM
Revson's Avatar
My understanding was the program for performance mode was in all f-body PCMs, to use it on Camaros, there is a way to wire it in from the PCM or tranny. I have to do more serarching, but I know it's out there.
Old Oct 6, 2009 | 05:10 AM
Iyyob's Avatar
u will have a 4 inch gap below the radio bezel and above the TA cig lighter area. basicly its a !Cassette Mod lol. its worth it
Old Oct 6, 2009 | 05:19 PM
VIP1's Avatar
It might be year-specific. I have a 4L60E in my Formula and it doesn't have any switch. I don't remember seeing anything about it on the option sheet either.
Old Oct 6, 2009 | 09:15 PM
Michigan BlckBrd's Avatar
+1 to yes easy
Old Oct 8, 2009 | 01:26 PM
Revson's Avatar
Here is the link to how to add the perf/normal mode switch to a Z/28. All you have to do is hook up a couple of wires.
http://www.trifectaperformance.com/t...rmanceMode.htm
Old Oct 8, 2009 | 02:50 PM
VIP1's Avatar
Thanks for the link, but it won't work for me since I have a 2001 LS1.
It may work for Revson though.
Old Oct 8, 2009 | 03:10 PM
RickyMartinZ28's Avatar
So, in theory, I could wire the switch into my 95 z28... Have a very mild transmission tune for putting around, and then go over and modify my performance tables in my pcm and install the switch and have a very aggressive transmission tune at the touch of a button?
If so, that would be pretty sweet. I assume you have the capability to change that table to whatever you want...
Old Oct 9, 2009 | 01:29 AM
Revson's Avatar
Yeah, my previous LT1 car was a 95 TA that already had the switch. I used LT1edit and had 2 programs, one where I messed with it and messed with it and got it to shift really well, almost like a Caddy, then in perf mode it would chirp the tires on 1-2,2-3 shifts. But the thing I was happiest with was I could upload a program for autocrossing, which I did alot of, where the car would go immediately to 2nd and stay there, so I didn't have to worry about downshifts coming out of corners etc. So I could drive to the track in normal mode, then hit the switch when I was ready to race. The only problem is when I sold the car about 3 years ago I gave the new owner all the programs and info, thinking I'd never get another LT1 car, so now I have to start all over from scratch and what I remember.
Old Oct 9, 2009 | 11:54 AM
1995blacktattop's Avatar
FWIW I remember hearing that a 95 camaro already has "transmission perform" installed on it by default. the trans am has the ability to not have that feature enabled for a better ride i suppose, but from what i heard the camaro's transmission is programmed to be in TP mode all the time. I always get people asking me what that switch is
you know what is really rare. a 95 Trans Am/Formula with both transmission perform AND traction control. i saw one at the T/A nats and had to take a pic. my car being originally from hawaii only has the trans perform. I have no traction control. interestingly, the car i took a pic of must have also only had 2:73 rear gears because it has no first gear selector. I also need to find one of those rubber cup holder things since my car never had one as long as i've owned it.
Old Oct 9, 2009 | 02:46 PM
spikester7878's Avatar
sure would ne nice to have a switch for tcs as well
Old Oct 11, 2009 | 06:29 PM
Revson's Avatar
Ok, I did some searching and googled, and I can't find a write up or instructions on putting a LS1 console in my 95. Anybody know of one? Or is it basically bolt in, straight swap?
