cleaning question
Old Dec 28, 2009 | 06:44 PM
layz's Avatar
Default cleaning question
what is the best way to clean underneath the hood of my camaro..what do i use to clean my nasty engine bay...help me out...
Old Dec 28, 2009 | 06:45 PM
jsteele90's Avatar
simple green is what i use.
Old Dec 28, 2009 | 08:32 PM
LS1 Sounds's Avatar
https://ls1tech.com/forums/appearanc...ngine-bay.html
From the sticky thread https://ls1tech.com/forums/appearanc...eck-first.html
Old Dec 28, 2009 | 08:52 PM
crimson_bird's Avatar
i pretty much followed that^ the first time i decided to clean my engine bay, but i used Purple Power cleaner/degreaser instead of Simple Green (too much controvery over its use, so i chose to just not try it).
the same way i cleaned the engine bay i did the underside of the hood.
it made a huge difference.... but not a big enough difference for me. so when it was all dry, i went back through it again doing a more detailed job. started at the passenger corner near the window and worked my way all the way around and to the other side. cleaning a small area at a time, just with the Purple Power and a rag. and then when i was done i repeated the original process again just for the final touch, and to get it washed/rinsed out really good. Came out PERFECT.
Old Dec 28, 2009 | 11:12 PM
InfernoTA's Avatar
Simple Green
Old Dec 29, 2009 | 02:03 PM
thecobrahunter's Avatar
Gotta be careful with getting Simple Green on the aluminum engine; heard it's not good; clean up immediately! I also use detail spray to clean up.
Old Dec 29, 2009 | 03:30 PM
hlaalu's Avatar
put a plastic bag over the fuse boxes and pcm, better safe than sorry.
Old Dec 29, 2009 | 06:10 PM
^yep, i did that too. and also the area right around the TB
