Removing smoke smell
Old Jan 4, 2010 | 08:19 PM
Johnny-LT1-runner's Avatar
Rockstar
Default Removing smoke smell
Ok guys, I've searched the hell out of this forum but there's nothing about this.
I got a new beater Z28 and the interior just reaks of smoke.
I thought about putting silica packets in there to asorb the smell but I'm not too sure. But I don't want to throw in 100 dollars worth of air fresheners either.
Any suggestions to get rid of the smell?
Old Jan 4, 2010 | 08:21 PM
camaro-94-z28's Avatar
smoke eliminator sold at local home depot.... been using it for years
http://www.homedepot.com/webapp/wcs/...0&ddkey=Search
Old Jan 4, 2010 | 08:43 PM
hlaalu's Avatar
roll down your windows and let your car sit in the sun for a few days, it worked for mine.
Old Jan 4, 2010 | 09:49 PM
McNord's Avatar
Start smoking, then you wouln't notice it. You could also try an open box of used coffee grounds in the back seat for a few days, thats worked for me.
Old Jan 4, 2010 | 10:28 PM
willis b otch's Avatar
if ya cant get rid of the smell why not change the smell lol burn a blunt
Old Jan 4, 2010 | 10:29 PM
scj's Avatar
scj
completely gut the interior and clean every panel with cleaner and a tooth brush, shampoo the carpet, and steam clean the headliner along with cleaning anything else out of the cars floors and etc.
the smoke smell is stuck to everything!
Old Jan 5, 2010 | 04:10 PM
barnat's Avatar
I AGREE WITH THIS GUY!
The headliner will more or less need replaced if it were a heavy smoker and holds most of a cars smell IMO The seats and carpet can be removed & cleaned.Wipe everthing else down inside the car including the rear hatch area with some murphys oil soap or something compareable.Dont forget about the inside glass too! That tar sticks to everthing my man and is why i dont smoke in my 35th LE LOL Ill pull over before ide ever fire up in my baby LOL She still has that new leather smell to her with only 26K on the clock and i intead to keep her that wayLooking and smelling good
Good luck and the Murphys oil soap will impress you and is safe for everthing
Old Jan 5, 2010 | 04:21 PM
Rockstar
That does not sound fun. I'm guess I'm in luck because I already have a mostly full bottle of Murphy's oil soap.
Old Jan 5, 2010 | 05:39 PM
TransAm11973's Avatar
coffee grounds work pretty good, you can have the car hooked up to an ionizer at a shop, also one of the biggest smell holders are your cabin a/c, heater filters. replace those and while your at it clean the ducts
Old Jan 5, 2010 | 06:05 PM
Rockstar
I'm assuming fresh coffee grounds, correct?
Old Jan 5, 2010 | 07:40 PM
im telling you, tape the top on the smoke eliminator(so it comes out all the time) and close the car up. that would be way over kill but if have the smell that bad it will do the job..... i clean carpets for a living in a high tourism community. when someone complains that there house/rentalcar/boat was smoked in, that is what we use.
Old Jan 5, 2010 | 07:52 PM
crimson_bird's Avatar
best one i've heard so far
Old Jan 5, 2010 | 07:58 PM
DaddySS's Avatar
if you google smoke eliminators there are several products like the one mentioned above. I have used Vamoose, Chemac Odor eliminator, etc. and they work pretty well. There is also a "bomb" where you set it off, close the car and wait like 12 hours.
Old Jan 5, 2010 | 08:00 PM
99ls1fbody's Avatar
My old car smelled like cigarette smoke sooo bad, i took it to my local bmw dealer and they put a ozone generator in it overnight and the smell was 99% gone!!
Old Jan 5, 2010 | 10:08 PM
spaz1's Avatar
We use an ozonator at work for all the used cars. It works mint.... has to do with the extra molecule in the ozone it bonds to the carbon or whatever.. not sure how it works but it does.
Old Jan 5, 2010 | 10:39 PM
scj's Avatar
scj
wear some gloves if you go the murphy's oil route, that stuff tends to break out skin kept in contact with it for a period of time on some people.
happens to quite a few ppl at my work.
Old Jan 5, 2010 | 10:48 PM
9WhiteCamaro9's Avatar
do what i normally do i get either Black Ice pine tree air freshners or get a can of something like Skoal Apple or Skoal Peach and just let the can sit in the car for 2 days and youll smell nothing but apples or peaches lol sounds crazy but it works
Old Jan 6, 2010 | 12:54 AM
6LITEREATER's Avatar
Save a few bucks, get some dynamat (or something similar)... Pull the interior, lay the sound deadener then shampoo the carpet and mats and clean each panel as you put it back in...
Car is better than new AND you accomplished more than just getting rid of smoke...
Old Jan 6, 2010 | 12:55 AM
Worked when?! You still smoke, lol!
Old Jan 6, 2010 | 01:29 AM
McNord's Avatar
LOL, actually it was a customers car a few years ago (67 chevelle) that had a BAD electrical fire under the dash, smelled of burnt plastic & rubber. Coffee grounds worked on that so I figured it would work on ciggs too.
